Old 10-01-2014, 04:35 PM   #1
b1barnes's Avatar
Steering Wheel
Question: Does anyone else have a steering wheel column that is not straight with the driver seat? Mine kind of points right and is not centered to the dash. Just a bit, but is noticeable.
Is this able to be adjusted?
b1barnes is offline   Reply With Quote
Old 10-01-2014, 04:49 PM   #2
phat phrog stunt crew
steering column most likely not adjustable. you will find yourself easier and cheaper to adjust than trying to find someone willing or able to make it straight to your liking.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 10-01-2014, 06:25 PM   #3
Sounds like a defect to me. I would mention it to the dealer.
Barbara
FR3 30DS 2014
BarbaraG is offline   Reply With Quote
Old 10-02-2014, 12:28 PM   #4
PDG
PDG's Avatar
Have you had your front wheels aligned? That may be the cause.
Peter & Linda
2014 FR3 30DS - Fiat 500
PDG is offline   Reply With Quote
Old 10-02-2014, 03:56 PM   #5
b1barnes's Avatar
Not the wheel, but the whole column is offset.
Old 10-02-2014, 04:36 PM   #6
Online_17's Avatar
Third Motorhome and all were like this...
Online_17 is offline   Reply With Quote
Old 10-03-2014, 02:21 PM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
We had the same problem. Our was to the left. Took it to a Ford dealer. They found the tie rod ends were not installed centered. They fixed that problem, aligned the front end and re-aligned the steering column. Now everything is fine. Oh, and this was covered under warranty by FR.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 12-04-2014, 05:24 PM   #8
Just took my first long trip and noticed my steering was at 10 and 4 not good ! Is this alignment or another issue ?
bigdocron is offline   Reply With Quote
Old 12-04-2014, 06:38 PM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
This is a steering column adjustment problem. Ours was the same way. See my comment above.
Old 12-04-2014, 09:22 PM   #10
Mine is the same and the dealer initially said that nothing could be done. After I saw the earlier post I stopped at the dealer and another guy at the service said, Sure no problem, bring it Ina we will take it Ford and have them fix it!! I take it in next week for the last list of warranty items, including the steering wheel.
Enconcapt is offline   Reply With Quote
wheel
