Old 03-29-2016, 05:20 PM   #31
Originally Posted by bubbles View Post
What I was saying is there is no tie rod adjustment that can be made for centering the steering wheel and that is what this thread was addressing. At least that's what I've been led to believe by Ford. Here is the lube point locations:
#5 is the lh tie rod end and #6 is the rh tie rod end and both are adjustable and therefore can be used to center the steering wheel.
Old 03-29-2016, 05:37 PM   #32
Kenny kustom's Avatar
Somebody needs to crawl under and snap some pics.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-29-2016, 06:57 PM   #33
Someone just doesn't understand tie rod ends are threaded and can be adjusted. It looks like it would be a time consuming job on the F53 as the tie rod end would have to be removed from the tapered socket and turned, re-installed, checked and probably have to repeat the operation several times. Too much trouble for most shops, BUT THEY CAN BE ADJUSTED!
Old 03-29-2016, 07:12 PM   #34
The pic only shows one end.
It is adjustable. We can't see the other end.
A simple pic would dismiss any arguments.
2016 Sabre 36QBOK
Old 03-29-2016, 07:16 PM   #35
Steering Wheel - Off Center
Pics!!!
2016 Sabre 36QBOK
Name:	ImageUploadedByForest River Forums1459296996.540802.jpg
Old 03-29-2016, 07:26 PM   #36
It is adjustable. We can't see the other end. A simple pic would dismiss any arguments.
The diagram shows #5, lh tie rod end and #6 is the rh tie rod end and both are adjustable and therefore can be used to center the steering wheel.
Your picture even shows the lh tie rod end. As I said before, they are both threaded and are therefore adjustable. Q.E.D. or in Latin, "ut supra probatum est".
Old 03-29-2016, 07:32 PM   #37
Left Coast
Call Ford and see if there's a left hand and a right hand tie-rod end........could be that the right tie-rod end is part of the cross shaft
Old 03-29-2016, 07:46 PM   #38
Only if they have a turn buckle on each end.
If they are both threaded, with a single buckle, then the drag link must be turned, which will turn both wheels.
Just post a pic!
2016 Sabre 36QBOK
Old 03-29-2016, 08:37 PM   #39
If they are both threaded, with a single buckle, then the drag link must be turned, which will turn both wheels. Just post a pic!
Regardless even without a turnbuckle, you just remove the nut on the tapered stud (with rubber boot) and remove the tie rod from the arm and turn it in or out to adjust. That's how they put new tie rod ends in the drag link.
Old 03-29-2016, 11:05 PM   #40
That's how they are replaced..
But to hell, if I'm doing that on an alignment. To jack up the front, pop out the tie rod, spin it, lower back down, check the toe....
Loosen the turn buckle and rotate the drag link.
2016 Sabre 36QBOK
wheel
