Old 03-29-2016, 11:26 PM   #41
Originally Posted by Kenny kustom View Post
That's how they are replaced..
But to hell, if I'm doing that on an alignment. To jack up the front, pop out the tie rod, spin it, lower back down, check the toe.... Loosen the turn buckle and rotate the drag link.
From the diagram and the picture, it looks like there are two independent drag links from the sector arm and to center the steering wheel, you would have to adjust each tie rod end independent of each other. Ford probably uses both ends with RH threads to save the expense of stocking a RH and LH threaded ends. Check with Ford and see if the part no.s are different. Regardless, IMO it's a funky design as was the "twin I beam".
Old 01-30-2017, 12:49 PM   #42
BlackJeep22's Avatar
Originally Posted by wahoonc View Post
I would get a second opinion... there are a several ways to "adjust" the steering wheel. Some are easier than others.
I need to have the one on my new Concord done too. Drives me nuts.
Aaron
Aaron,
Did you ever get your steering wheel straight? Mine sags to the right about 10-15. It's in the shop right now having some factory paint redone... thought I might have them take a look at it while it's there.
Thanks, Steve & Deb
2016 Coachman Concord 300DS-SOLD
2011 36QSH TIFFIN PHAETON
Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
BlackJeep22 is offline   Reply With Quote
Old 01-30-2017, 01:23 PM   #43
Left Coast
Twin I beam was a loser!
Old 02-01-2017, 04:51 AM   #44
World Wide Wanderer
wahoonc's Avatar
Originally Posted by BlackJeep22 View Post
Aaron,
Haven't gotten a chance to deal with it yet. Work keeps getting in the way...
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 02-01-2017, 04:52 AM   #45
World Wide Wanderer
wahoonc's Avatar
Dunno about that. Couldn't seem to wear them out.
Aaron
Aaron & Rhonda
Old 02-01-2017, 08:01 AM   #46
Left Coast
Replaced a lot of bushings in them
wheel
