Old 05-10-2014, 05:27 PM   #1
Steps Broke!
My steps broke this morning while I was going in carrying a load. They broke while I was on the third step and sagged about 4 inches, dumping me on my head, not hurt, just a few scrapes and I'm glad that only my dog witnessed it. He would never laugh at me. I called Coach-Net and they said they would send someone out to fix it, BUT they don't do warrantee work and would have to pay for parts and labor. Their technical advice was useless, the tech had no clue what to tell me. I don't fit under the skirt, so can't really look at it. I will call the dealer on Monday morning and get the runaround again. They just might get it delivered into their show room at 60 MPH.
Mandoholic and Bassbabe
2014 FR3 30DS
Salem, Oregon
Mandoholic is offline   Reply With Quote
Old 05-10-2014, 11:42 PM   #2
StephanFR3's Avatar
When was your rig built? Is it an FR3 30DS. What brand are the steps? My steps broke on my first trip. The bolt that the gear rotated on Sheard off. On my trip I stopped by Elkhart and the upgraded my steps to kiwi which are a lot stronger. That was about a year ago, no problem since.
Sent from my SAMSUNG-SM-G900A using Forest River Forums mobile app
StephanFR3 is offline   Reply With Quote
Old 05-11-2014, 05:50 AM   #3
ARLO
%^733 Steps
The Lippert steps on my 2010 Flagstaff signature ultralite are junk. Repaired them with bolts instead of rivets. I feel that these are bad enough that there should be a
factory recall.
rlocicero is offline   Reply With Quote
Old 05-11-2014, 05:56 AM   #4
B and B's Avatar
My steps broke at the rivet as well. I bought bottom stair supports now to lengthen the life of them. Going to put together a hardware kit so I can repair while on the road.
B
Old 05-11-2014, 06:11 AM   #5
tomjsas's Avatar
factory recall.
The ones on the previous camper broke at the rivet. I too fixed them with bolts, much better. I use a step support now to help alleviate some of the pressure and hopefully make them last a bit longer. Also helps with movement of camper going in and out.
Tom - 2014 8289ws, 2011 Chevy 2500HD
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
tomjsas is offline   Reply With Quote
Old 05-11-2014, 01:12 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
My contention all along with the FR3 is that the Kwikee 3 step entry is not strong enough and sag every time you step on the bottom step. I went as far to email Steve, the warranty manager for the FR3 to ask if they would replace them with a 2 step. I would pay for the difference. That was 2 weeks ago. Have not heard a word back!!!! So much for customer service. I've even considered cutting off the bottom step. When I use the middle step there's not as much sag. Unfortunately, cutting off the bottom step would void the warranty. After what happened to Mandoholic, I might just say the hell with the warranty.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 05-11-2014, 01:42 PM   #7
StephanFR3's Avatar
I think Steve left forest river.
Old 05-11-2014, 02:22 PM   #8
HAPPY WHEN RV'ING
drivmsafe's Avatar
Seems you're correct stephanfr3. I see a new name on their contact site. Guess I'll send off another email and see if the new person will respond.
Old 05-11-2014, 03:52 PM   #9
Add another to the list of busted steps, rivet is the common weak point. Like the others I replaced with a bolt and a stair support. Cheap junk in my opinion.
meck51 is offline   Reply With Quote
Old 05-11-2014, 04:39 PM   #10
I finally got under the steps and the bolt that holds the gear on broke. It's a half inch bolt, but seems to be rusted halfway through. Once I got the motor off, the gear just fell down, held in place by the actuating rod. I'll get up early in the morning to deliver it to the dealer along with a very angry customer. Yes I'll wait.
2014 FR3 30DS
Salem, Oregon
Old 05-11-2014, 07:43 PM   #11
StephanFR3's Avatar
Replacing the bolt which is a special part not just a bolt. It won't last. You need better quality steps. They upgraded mine to kwikee. The original lipped broke in the first 2 weeks. The upgraded kwikee are almost a year old with no problems.
Old 05-12-2014, 02:19 PM   #12
Motoring
grotto69's Avatar
Step broke for mr too last year. I took it into camping world for warranty work. They fixed it and said those steps are very common For me it was a bolt at the gear box that broke in two. Now I put levelers under them when parked. But they said I should be fine. Time will tell
I didn't want to loose 3rd step because I have leveled where I needed a 4th step the front was so high.
Grotto
grotto69 is offline   Reply With Quote
Old 05-12-2014, 03:06 PM   #13
StephanFR3's Avatar
This is what I have now. Much better than original lipped one's.
ID:	52255   Click image for larger version
ID:	52256   Click image for larger version
Old 05-12-2014, 03:29 PM   #14
StephanFR3's Avatar
Wow didn't realize they cost $855.
Old 05-12-2014, 04:14 PM   #15
StephanFR3's Avatar
http://ervparts.com/rv-steps/series-...e-step-8in.htm
On sale $650.
Old 05-12-2014, 04:44 PM   #16
acadianbob's Avatar
My steps broke too but it was because I forgot to fold them in before I pulled the trailer out of the barn!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 05-12-2014, 04:56 PM   #17
StephanFR3's Avatar
I think this the part that broke on my lippert steps. $6.00 part. You would need a drill and easy out to remove the threaded piece that sheared off in the welded nut.
Old 05-12-2014, 04:57 PM   #18
StephanFR3's Avatar
Pictures
Old 05-12-2014, 04:58 PM   #19
StephanFR3's Avatar
Could not post picture???
Old 05-12-2014, 06:04 PM   #20
Same part is broken on mine. I'm going to let the dealer fix it since we have even been camping yet.
2014 FR3 30DS
Salem, Oregon
