Old 04-17-2017, 03:58 PM   #1
Storage Door Hinge
Noticed recently that the large storage door on our FR3 30DS , passenger side, hinge is failing and the door is hanging lower than normal. Anyone else had this problem and if so what was your fix? Thanks.
LDStaas is offline   Reply With Quote
Old 04-17-2017, 06:01 PM   #2
leisurelarry's Avatar
I've stuck a wood match stick in the hole and used a slightly longer screw.
leisurelarry is offline   Reply With Quote
Old 04-17-2017, 06:38 PM   #3
Cigarman's Avatar
Mine did the same thing. I used toothpicks and glue then screwed it back together and holding well.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
Cigarman is offline   Reply With Quote
Old 04-17-2017, 08:09 PM   #4
I am sorry,I failed to state that it is outside and at the rear of the coach on the passenger side
Old 04-17-2017, 10:46 PM   #5
That's the door I repaired using my stated method. It has remained tight since the repair.
Old 04-29-2017, 11:28 PM   #6
wayne and sherry's Avatar
What hole? Can you post any photos of your repair? Thanks eh
wayne and sherry is offline   Reply With Quote
Old 04-30-2017, 12:37 PM   #7
Also once the side compartment doors are open, on the flat edge of the side door there are little rivets. Well most if not all have disappeared.. what are folks doing about that?
Old 05-01-2017, 12:54 AM   #8
Simply pulled out loose original screw, inserted a full size wooden stick match and screwed in a longer screw. Not experiencing any popped rivets on any of my doors.
Old 05-01-2017, 09:19 PM   #9
Attachment 136458
Thanks for the pictures
Old 05-01-2017, 09:36 PM   #10
Your Welcome!
door, storage
