Old 07-15-2015, 03:57 PM   #1
StephanFR3's Avatar
Temp electrical adapter
Is there an adapter for this or is this 220?
StephanFR3 is offline   Reply With Quote
Old 07-15-2015, 03:59 PM   #2
StephanFR3's Avatar
This is pretty wired at a family members home and would like to plug in.
Old 07-15-2015, 04:10 PM   #3
fonzie's Avatar
what do you have on your FR3: 30 amp or 50 amp male plug in?
Fonzie
Old 07-15-2015, 04:10 PM   #4
I would have to test it before using it. It tells me that it is 220V.
03 F-250, 7.3 L, CC, Lariat; 07 Cedar Creek 30 LSTS Silverback; the DW and me.
dnismenace is offline   Reply With Quote
Old 07-15-2015, 04:13 PM   #5
Without being there with a multimeter I can't be sure, so take this at your own risk..
It looks like a L14-30 (it will likely say this on plug somewhere) which has 2 hot wires for 240 also a ground and the neutral. An adapter that just uses one of the hots and the neutral and the ground should feed your rv just fine.
If it is the plug that I think it is, and it's wired correctly, here is how it and the adapter would be wiredClick image for larger version
Name:	ImageUploadedByForest River Forums1436994765.291892.jpg
ID:	82992Click image for larger version
Name:	ImageUploadedByForest River Forums1436994787.291919.jpg
Scott
patanke is offline   Reply With Quote
Old 07-15-2015, 04:21 PM   #6
jaibyrd's Avatar
That's a 30 amp 4 wire twist lock. Commonly used for a generator. Should be wired 2 hots a neutral and a ground for 240V. They do make an adapter that will only pull from a single hot giving you 120v for a 3 wire application like your rv. Not sure if you'd find it local, but HD has them on their website.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
jaibyrd is offline   Reply With Quote
Old 07-16-2015, 02:21 PM   #7
StephanFR3's Avatar
Okay found one that went from theL- 14 -3 to 50 amp. But I already have a 50 to 30 adapter so I Daisy chain these and pow fry microwave and small electric fan every thing else seems to work an generator power. Fan is cheap, but where is the fuse for microwave?
Old 07-16-2015, 02:24 PM   #8
StephanFR3's Avatar
Pictures
Old 07-16-2015, 02:28 PM   #9
StephanFR3's Avatar
Pictures 2
ID:	83062   Click image for larger version
Old 07-16-2015, 02:49 PM   #10
jaibyrd's Avatar
Not sure on the fuse. Do you have an EMS like the progressive unit? May want to make sure you have clean power on the gen cord before trying it again. May have been wired wrong.
Old 07-16-2015, 02:50 PM   #11
jaibyrd's Avatar
Did you check to see if it tripped a breaker in your rv panel?
Old 07-16-2015, 04:00 PM   #12
StephanFR3's Avatar
Blown 20 amp fuse inside microwave oven fixed for $2.50
Old 07-16-2015, 04:04 PM   #13
StephanFR3's Avatar
Needed special t 20 bit with hole for 2 of the screws glad I had this cheap harbor freight set.
Old 07-16-2015, 04:20 PM   #14
StephanFR3's Avatar
Well spoke too soon. Microwave fan runs clock and control panel works, plate spins. Just not heating water.
Old 08-08-2015, 08:01 PM   #15
StephanFR3's Avatar
Found 2nd hidden blown fuse in microwave 5KV 0.8A. Inside plastic holder near magnatron. Had to order part.
Old 08-10-2015, 01:41 PM   #16
StephanFR3's Avatar
Yeah! fixed microwave for 10 bucks total. And have 1 of each spare fuses.
electric, electrical
