Old 10-24-2014, 01:17 PM   #1
Thermostat Fan
When running the thermostat furnace (or A/C I assume), it seems that the fan (whether on Low or High) runs constantly. I've only been plugged in so far, so not sure if it's the same when you're just running the batteries.
I like the white noise of the fan while sleeping so not a big deal but does the fan always run when you have the thermostat on?
Seems you should be able to either have the fan on or off and the heat/A/C on or off separately?
I haven't sat down and read the manual on it yet, just an observation.
Anyone know if anything can be done?
Meathouse is offline   Reply With Quote
Old 10-24-2014, 01:40 PM   #2
scayne62's Avatar
To make the fan cycle with the A/C or furnace the fan setting needs to be set on auto. having it on hi or lo tells it to stay on all the time.
scayne62
2014 Prime Time Lacrosse 329BHT Luxury Lite Touring Edition
2015 Silverado 2500HD DMAX
scayne62 is offline   Reply With Quote
fan, thermostat
