Old 12-21-2017, 07:57 PM   #1
Thermostat Timer Function
Atwood Manual not so easy to understand but I am trying to use the timer function to turn on the furnace so many hours in the future. Can anyone tell me how to program this
George (Retired US Air Force)
Beverly (Retired Travel Agent)
2018 FR3 30DS
fritzg2 is offline   Reply With Quote
Old 12-27-2017, 09:14 AM   #2
Thereís a timer function?
alexchuang is offline   Reply With Quote
Old 12-27-2017, 09:37 AM   #3
bubbles's Avatar
This is pretty much straight forward:
7. On/Off timer setting
 When the system is on, setting the timer will turn off the unit after the programmed hours were counted down. When the system is off, setting the timer will turn on the unit after the programmed hours were counted down.
 Press button once to activate on/off timer programming mode. Timer LED and temperature display area flash for 3 seconds showing the number of count down hours left. Thereafter, Timer LED flashes and temperature display area shows the timer setting.
 Press again to set the timer from 1 to 24 hours in 1 hour incremented in a round robin pattern.
 Hold down this key will change the timer setting automatically every half second.
 Press until the display shows “—“ will cancel the timer setting.
 Should there be no further button press, system will exit from on timer programming mode automatically.
 Timer LED will light up if on/off timer is set.
 Press to start or stop the air conditioner will also cancel the timer setting.
thermostat
