Old 08-09-2017, 06:34 PM   #1
Tilt awnings?
So we moved up from manual awnings to the automatic ones on the fr3. Is there any way to/need to Drop one side for rain runoff. Thx
CSroo is offline   Reply With Quote
Old 08-09-2017, 06:51 PM   #2
Bikersarge's Avatar
I've heard you can't, but I don't know the tricks like some here on the forum may know.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 08-09-2017, 06:56 PM   #3
rsdata's Avatar
I don't know if you have the same type as I do, but there might be a twist knob on the lower horizontal arm from the ends of the awning to the camper about 1/2 way from the awning... loosen the knob then push down and in toward camper on that end of the awning... it should slide on that adjustment spot, then turn the knob to lock it down
hope that gets it
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 08-09-2017, 09:39 PM   #4
So I figured it out. ....on the side of the awning arms it says pull here to lower..hope this helps someone
Old 08-09-2017, 09:40 PM   #5
hope that gets it
Thx
Old 08-10-2017, 01:32 PM   #6
pull down in middle of arm that has a pivot point. put back in place before putting awning away.
Combatcoal is offline   Reply With Quote
awning
