Old 01-29-2019, 08:07 PM   #1
Crossfire8207's Avatar
Question Tire pressure
Hello my happy campers!!! Quick question on optimal tire preasure for 245/70R 19.5G
Looking at the viair tire pump and wanted to make sure it can handle rv tires? Thank you again in advance
Crossfire8207 is offline   Reply With Quote
Old 01-29-2019, 08:26 PM   #2
Mr. Dan's Avatar
Which Viair compressor are you looking at? There are several models with various specifications/capabilities.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 01-29-2019, 08:53 PM   #3
Hi thank you for responding right now considering the
VIAIR Corporation - 400P-RV Automatic Portable Heavyweight Series Air Compressor
Old 01-29-2019, 10:33 PM   #4
i have the rv400p and i use it to take my tire pressure up to 110psi. i think it has a duty cycle of something like 15 to 20 minutes and then it must cool off. there is a rv450p model which goes to the same pressure and has a continuous duty cycle. the rv400p works just fine for us.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-30-2019, 05:51 AM   #5
Smile
You guy's are awesome on here thank you chickdoe for your response you have made my decision easier for purchase
Old 01-30-2019, 06:34 AM   #6
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Optimal tire pressure is whatever the manufacturer stamps on the sidewall of the tire in my opinion.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 75
rjshiflet is offline   Reply With Quote
Old 01-30-2019, 06:43 AM   #7
Rv in storage
Thank you I wanted to know if you could tell me my class A is in storage and forgot what the pressure was?
Old 01-30-2019, 06:46 AM   #8
"On the road again"
rjshiflet's Avatar
Gotcha. I've known of people who think that is only a MAX on the side of the tire, and if they have less than a full load, perhaps they should deflate some.
Happy travels!!
Old 01-30-2019, 06:49 AM   #9
Thank you, yes I agree less than max load unless loaded
Is that normally less then 95 correct?
Old 01-30-2019, 09:53 AM   #10
edm
There Load and Inflation Charts for MICHELIN RV Tires and also GOOD YEAR RV tires on line. they will guide you through the proper inflations.
Good luck and safe travels.
edm is offline   Reply With Quote
tire
