Old 11-21-2015, 10:50 AM   #11
Night Stone's Avatar
Originally Posted by StephanFR3 View Post
Oh and cheap valve extensions cause leaks.
If you get the airless valve extenders you wouldn't need to worry about it air leaking.
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 11-21-2015, 08:40 PM   #12
Former Full Timer
Duckogram's Avatar
If you put alligator caps on you don't need extenders and you don't need to remove the "simulators" (aka wheel covers). If you decide to install a valve mounted TPMS you will need a 120* or so airless elbow for the outer dually or braided hoses.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 11-22-2015, 12:05 PM   #13
DavidMPDK's Avatar
As a retired equipment operator I'm not a strong advocate of add-on valve extenders. I find that they have a tendency to slow leak. When you screw off the valve caps or TPMS (Tire Pressure Monitor System) they unscrew also "causing leaks". The first thing I do as #1 mod is buy the correct single metal extension valve stems and have the tires broke down and installed. This not only makes it easier to check pressure and add air but gives a lot better support for the TPMS. They now extend well beyond the hub caps.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
Days Camped 2015 56
Days Camped 2016 121 and counting
DavidMPDK is offline   Reply With Quote
Old 12-04-2015, 05:42 AM   #14
Does anyone use and/or have a tire monitoring system installed? Thanx...
The Bratmobile is offline   Reply With Quote
Old 12-04-2015, 05:54 AM   #15
Yes Lots,Do a Search at Top Days of Reading! Youroo!!
youroo is online now   Reply With Quote
Old 12-04-2015, 06:10 AM   #16
RSchleder's Avatar
Yes, I have a system on my TT. It provides continuous air pressure and tire temp on a small screen suction cupped to the dash. I don't remember the brand name and the TT is in storage. The only thing I'd do differently is buy the type that allows air to be added "thru" the individual monitors on each wheel. I have to unscrew each monitor to add air, then replace it after airing up the tire, which is sometimes a bit inconvenient. For less than $400, I get a lot of piece of mind with my system so I'd definitely purchase them again.
Days camping (2015)----88 days
Days camping (2016) ---110 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 12-04-2015, 02:03 PM   #17
The valve you see in the rear is most likely the extension for the inner tire. Look in the slots on the wheel cover for the outer tire valve.
welder is offline   Reply With Quote
pressure, tire
