Old 05-27-2019, 10:11 AM   #1
Tire Question
Hi gang,
I noticed this “bump” on my driver side rear tire on my 2016 FR3 30 DS. I haven’t taken it out since last June and I would assume the tires are at least 5 years old. I have 22K miles on the coach.
Should I be concerned with this? Any recommendations on what should be done if anything? I attached a picture.
Thanks!
MarkA is offline   Reply With Quote
Old 05-27-2019, 10:39 AM   #2
SeaDog's Avatar
ripples in the sidewalls are common on tires and don't normally indicate a problem. One of the tire guys will be better able to explain whey this happens. My truck has several.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-27-2019, 01:57 PM   #3
Thank you, SeaDog! Glad to hear it’s Normal.
Old 05-27-2019, 10:09 PM   #4
There is a great site where you can get everything imaginable about tires: RV Tire Safety
Roger Marble writes the blog and he has over 40 years experience as a tire engineer. He can answer any question too... Great info source.
__________________________________________
2014 Spartan 1032
2015 GMC 3500HD Denali 4WD/Duramax
RockyMtnMarty is offline   Reply With Quote
Old 05-27-2019, 10:59 PM   #5
That’s great info, thank you.
tire
