Old 04-17-2014, 09:21 AM   #11
PhotoMaster's Avatar
Originally Posted by strangerj View Post
Took mine to a truck roadside service place and they replaced all valve stems with custom bent ones for $100. Extenders will leak. Now I can air
my tires without even touching the wheel covers.
I'm liking this idea. I'm seeing losses so I got the TST tire pressure monitoring system (TM-507SE). I have it installed on my dually's (4 sensors) and having trouble getting them on the front. I'm thinking the custom bent valves may solve my problem. I wish I had known about them before I got the extenders.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 04-17-2014, 09:26 AM   #12
Amen. We were told that the extenders were a back up to the valve cores but had the same experience with a low tire due to the extender leaking. Our solution was a new extender but we've become a lot more vigilant on tire checking. Our normal operating mode is to change drivers every hour (or closest rest stop thereto) and it now requires a visual on the tires in addition to the toad
Geri is offline   Reply With Quote
Old 04-17-2014, 09:32 AM   #13
Mddle of the Rd Extremist
MeepMeep's Avatar
Check this website: Tire-Man: Products
Bought some from there for my RAM Dually and they are fantastic. They replace your current valve stems with the longer for the inner and curved for the outer so they come out of the same hole for servicing. $135.00 for the complete kit....
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 04-17-2014, 10:06 AM   #14
Originally Posted by JerseyGuy View Post
I took off the wheel covers and I was able to install them. That was after dropping them several times and then moving the MH a few feet forward so that I could get them from between the tires. The little extra effort in the beginning could have saved some frozen hands and some very bad language.
Hopefully Spring will come to New Jersey soon...
This may sound like a dumb question, but how do you take the wheel covers off? I assume I'd have to remove all the lug nuts?
2014 FR3 30DS
Old 04-23-2014, 07:14 PM   #15
StephanFR3's Avatar
Don't you have a inbound coaxial jack for rig in rear storage compartment driver side near power converter.
Sent from my SAMSUNG-SM-G900A using Forest River Forums mobile app
StephanFR3 is offline   Reply With Quote
Old 04-23-2014, 07:17 PM   #16
StephanFR3's Avatar
That is for gem hunters first post.
Old 04-24-2014, 02:13 PM   #17
Gem Hunters's Avatar
I assume you are referring to the cable tv outlet located in the outside compartment. Yes I do have that outlet. However I have been advised by numerous satellite tv providers that they do not recommend that you try to connect your satellite feed to this cable tv outlet. That is why on the trailers and 5th wheel rigs Forest River manufacturers they install a special outlet specifically for portable satellite tv antennas in addition to the cable tv outlet. They look the same but are not the same.
Gem Hunters is offline   Reply With Quote
Old 04-24-2014, 02:16 PM   #18
Concerning the question of how do you remove your wheel cover. The answer is to remove the decorative lug nut looking bolts. These only hold on your wheel cover and not the tires. You should have received a special small looking lug nut tool with your FR3 for this specific purpose. Good luck!
Old 04-24-2014, 04:48 PM   #19
StephanFR3's Avatar
Hey gem, I not being smart, but what is different in a coax connection. Does the satellite use 2 cables? Do you have a link to the site that you're referring to? I don't have a satellite, so I'm just curious.
Old 04-24-2014, 04:58 PM   #20
I have a lot of satellite experience. If you start a new topic I can answer your questions
jwedell is offline   Reply With Quote
