Old 05-16-2015, 05:07 PM   #1
FireSurf's Avatar
Toilet lost pressure
Toilet was flushing fine now it is just dribbling water out when flushed. Any ideas what might be wrong...camping as we speak.
2015 FR3 30DS
FireSurf is offline   Reply With Quote
Old 05-16-2015, 05:13 PM   #2
Debris in the supply line/valve.
Old 05-16-2015, 07:15 PM   #3
Technorick's Avatar
Disconnect the toilet fitting from the rear. The fitting is on the right rear and may take a pair of channel locks to loosen. Make sure you shut off the shore water and don't have the pump on b4 you do this. Also reLease the pressure on the line by opening the cold water faucet in the bath room. And press the pedal to let the remaining water pressure drain. Once the water stops flowing unscrew the fitting in the right rear of the toilet and have a small cup to catch he water.
Once disconnected you may need to run the water via the pump to remove the blockage. I used an old washer drain hose placed over the fitting that comes over the wall connected to an empty water jug. Even after flushing the line after winterized I have found fine plastic pieces in the screens.
If you don't have the tools or time to this while camping keep a jug of water in the bathroom you can flush by adding the water manually until you get home.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 05-17-2015, 12:34 AM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
What technorick said. If that fails, you may have a bad valve, which was my problem when I also had the same problem you're having.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 05-17-2015, 03:16 PM   #5
FireSurf's Avatar
Thanks for the help going to wait till we get home to work on it. For now filling jugs for manual flush.
2015 FR3 30DS
Old 05-17-2015, 08:09 PM   #6
fpo1123's Avatar
I just had this happen in nags head. I tried to pull the valve and couldn't get it t out next to the wall so I pulled the toilet (all 2 pounds) pulled the valve and cleaned it out. Flushes like a real toilet now. Think I am going to dump this one and get a porcelain one when I get home
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 05-18-2015, 02:45 PM   #7
FireSurf's Avatar
Got home took the toilet out and found tons of debris caught in it. Thanks for the info and help. It flushes like new again.
2015 FR3 30DS
Old 06-15-2015, 10:45 AM   #8
Rolling Magic's Avatar
Ya, it will take a few times before it truly clears. I figure I'm an expert at this now...
Rolling Magic is offline   Reply With Quote
Old 06-15-2015, 07:43 PM   #9
fpo1123's Avatar
Replaced the toilet with the 310. Flushes cleaner and doesn't creak when people sit on it now.... lol.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
pressure
