since all most all toliets and WH are the same in your FR3 as my TT or my fifth wheel, I will respond. yes this happens. I experienced 4 years ago in Amana Iowa at the Frogtober Rally. Its a simple fix.
turn off water and water pump
unscrew water supply line, have a small bucket to lay line into
unscrew 2 bots holding toilet down, and remove
place a solo cup with some water in hole to prevent smells
take toilet outside and clean screen between water line and toilet. Scraping with a flat head screwdriver helps and spraying with a water hose to rinse seems to do the trick
now, if you do this around camping friends, you wil never hear the end of it, but you will be back in business
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
