Old 01-17-2017, 12:46 AM   #1
Toilet Swap
Has anyone upgraded their toilets? I am looking to upgrade to the Dometic 320 series China elongated bowl. Just curious if anyone has done the swap and if it fits with no alterations.
Ebirep is offline   Reply With Quote
Old 01-17-2017, 08:18 AM   #2
AD2
On our 28ds it was a direct change. Everything fit with no changes.
Anthony & Amy Dennis
AD2 is offline   Reply With Quote
Old 01-17-2017, 01:50 PM   #3
StephanFR3's Avatar
While you are at it add a short loop of hose and and a small inline filter screen to catch the debris from the water tank. It will keep the debris out of the screen on the flush valve which is a pain to get to. You just catch the debris in a spot you can get to without making a mess.
StephanFR3 is offline   Reply With Quote
Old 01-17-2017, 08:38 PM   #4
Thanks for the replies. I was concerned about clearing the raised area on the floor behind the toilet. I see the 28DS has this also I wonder if it's dimensions are the same as the 30DS. Adding the additional filter and hose sounds like a good idea.
