04-01-2015, 10:28 AM
Tools Needed for Sway Bar Quick Fix
I'm planning on doing the sway bar quick fix but my MH is parked at a storage lot. Our driveway is too steep to drive the MH up so I'll have to do this at the storage lot. Can anyone tell me which tools I will need to do this? I don't want to drive back and forth because I have the wrong size wrench.
Ed & Stephanie
SFC, USA (retired)
04-01-2015, 12:07 PM
What is the sway bar quick fix?
JeNNY (FR3/30DS)
04-01-2015, 12:18 PM
17 or 18 metric wrench two ea. its one or the other cant remember off hand and a small jack to use on rear sway bar too line up holes . or second person. But and easy job on the level.
Carl & Bette
2018 Leprechaun
NEW YORK
04-01-2015, 12:22 PM
JeNNY (FR3/30DS)
a must for FR3 owners 100% handling improvement.
just move front sway bar link to inboard holes on sway bar, than repeat on rear which has two bolts per side on rear bracket spins a round. no more wind blowing you off road.
Carl & Bette
2018 Leprechaun
NEW YORK
04-01-2015, 12:52 PM
10-4. I'll take a look and get pics for everyone
JeNNY (FR3/30DS)
04-02-2015, 08:09 PM
Boy looking at the Minnesota weather for the next week or so looks cold!! It may be a few weeks before I get out to look at the sway bar links on JeNNY. Any one have and before and after pics of the sway bar links from out board to in board? I'd sure like to see some if anyone's got any.
JeNNY (FR3/30DS)
04-06-2015, 03:29 PM
Used a 18mm and 15mm for the bolts. A small jack came in handy to line up the holes. Will test it out later this week.
Ed & Stephanie
SFC, USA (retired)
04-07-2015, 01:30 AM
When our DS30 was in for service I asked the dealer about the CHF. They didn't know about it, which surprised me. I explained adjusting the ford sway bar was improving them handling and asked them to look at adjusting the sway bar since they were preforming a oil change and Lube. When I arrived after the service they said that my DS 30 does not have sway bars. I have not looked my self since parking it in storage. Could it be possible this 6 month old DS30'does not have sway bars ?
04-07-2015, 10:14 AM
HAPPY WHEN RV'ING
Every one I've seen has a front and rear sway bar. Was this a RV dealer, or Ford? I'd be looking for a new dealer (lol). But then you need to realize that RV dealers do not work on the chassis. Just the coach. But still, they should know.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
04-07-2015, 02:20 PM
Ford Chassis Fron and Rear Sway bars
Class_A_brochure_2013_LoRes.pdf
Take a look at the attachment, The front and rear sway bars(Stabilizer bars) are listed. The attached is for year 2013 chassis, you can probably find the same for 2012 or 2014 chassis. My FR3-30 is 2014 and I have them on mine.
04-13-2015, 08:52 PM
I did my 2015 DSL 30 and didn't find any adjustments on the front but did on the rear. The tools needed were 18mm and 15mm, a deep well socket did come in handy as well as a small jack. My unit drove well prior but thought if I could get a little better it might be worth it and it was. The movement was far less after doing the adjustment.
04-13-2015, 11:54 PM
This is helpful, thank you.
04-20-2015, 06:54 PM
Rear Sway Bar mount
15/18mm was spot on. Though you may want to verify the rear sway bar is actually mounted to the rear axle. I found mine was just hanging down on the RH side. Looks like its happen to others, where a bolt falls out. Only have 5k miles on ours, which we just bought used. I've ordered a new bracket since it was bent out of whack for $19. That along with some locktite we should be good to go.
04-20-2015, 07:04 PM
Sway bar done.. That was easy... And made a big difference
04-21-2015, 03:16 PM
I'll be doing my sway bars this weekend
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
04-24-2015, 10:33 AM
Pictures sway bars FR3
Rear bar 1 bolt and 1 stud with nuts per side ,swap ends of bracket , front 1 bolt and nut per side move to inboard hole . A jack maybe needed on rear to help line up holes. THESE PICTURE ARE AFTER JOB DONE, piece of cake
Carl & Bette
2018 Leprechaun
NEW YORK
04-25-2015, 11:38 PM
Got mine done tonight.
2015 FR3 30DS
