Old 10-30-2015, 02:26 PM   #1
Total Towing Capacity for FR3 28DS
Does anyone know what the total amount of weight that can be towed behind the FR3 28DS is?
philv is offline   Reply With Quote
Old 10-30-2015, 02:54 PM   #2
Former Full Timer
Duckogram's Avatar
The answer is dependent on your load and hitch. You unit comes with a Class III rated at 5000 lbs trailer with 500 lbs vertical tongue weight. You can upgrade to a Class IV for higher capacity but you still should not exceed the GCWR (23,000lbs) so if you want to tow the double decker with the boat over the car you will have to give up cargo load.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
towing, towing capacity
