Old 01-21-2018, 09:08 PM   #1
LytesOutFR3's Avatar
Towing a boat with stock hitch
Is anybody towing a 20-25 ft boat with their stock hitch?
LytesOutFR3 is offline   Reply With Quote
Old 01-21-2018, 09:49 PM   #2
davel1971's Avatar
What does the boat and trailer weight? What's your RVs towing capacity? Not just the hitch capacity.
David & Lynn
Old 01-21-2018, 11:12 PM   #3
tpatino14's Avatar
We tow our 21í with the receiver that came with the RV. Use the same hitch we use with our F150.
2015 Forest River Forrester Class C2250
tpatino14 is offline   Reply With Quote
Old 01-22-2018, 05:14 PM   #4
edm
If you are towing with a fr3 your towing capacity is 5000 lbs.
edm is offline   Reply With Quote
Old 01-22-2018, 07:17 PM   #5
I did some searching online and found out my exact model boat weighs around 4600 lbs with the trailer. The rating on our receiver says 5000 lbs. So overall weight and tongue weight are pretty close to max. Iíll probably take it to a shop and have it upgraded/welded in.
Old 01-22-2018, 07:43 PM   #6
That weight is without gas, batteries and gear so plan accordingly.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 01-22-2018, 08:01 PM   #7
And trailer
Jmkjr72 is offline   Reply With Quote
Old 01-22-2018, 09:50 PM   #8
No it includes trailer. Trailer is around 1100 lbs.
Old 01-23-2018, 06:31 AM   #9
davel1971's Avatar
It could easily weight another 1000 lbs once loaded and full of fuel
David & Lynn
Old 01-23-2018, 05:53 PM   #10
Yeah Iím sure of that! Iím going to get the stock unit upgraded anyway. Itís too close to the max rating leaving no breathing room.
Old 01-23-2018, 07:20 PM   #11
So I was searching through the owners manual. My 30DS has a 18000 lb GVWR and a GCWR of 23000 lbs. which leaves me with 5000 lbs towing capacity whether I upgrade the hitch or not...
Old 01-25-2018, 01:36 PM   #12
Seeing boats behind class-a's all the time, and reading this thread, may I pls ask the following:
Am I the only one that wonders?
HOW THE HECK do you get the boat off the ramp in the water?!?!?
DutchRv is offline   Reply With Quote
Old 01-27-2018, 01:46 PM   #13
tpatino14's Avatar
Not much different then when we use our truck. Sometimes cannot go that deep in water with wheels as you would with a truck. We back up until the boat floats or the RV wheels touch the water and then drive the boat off. Knock on wood, we have not experience any issues launching with our RV.
Old 01-27-2018, 02:15 PM   #14
PPST Wannabe
kenandterry's Avatar
Huh.
I can almost guarantee that if I was trying to launch a boat using my Georgetown....there would be some significant water intrusion
in my rear luggage compartments if I went in as far as having my rear tires touching water. I have a fair amount of motorhome real estate past my rear axle......and Iíve seen longer.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-27-2018, 02:17 PM   #15
An FR3 would garuanteed be scraping on (steep) ramps...
boat, hitch, towing
