Old 03-20-2016, 09:51 AM   #41
7 Year Class A RV'er
Nope. Just hooked mine up to leave the campground in a few minutes. Key off and out of ignition, transfer case in neutral, transmission in park, brake off. Be SURE transmission is in park, not neutral, or you'll burn up the transmission (automatic).
2015 Legacy SR340 360RB
Old 03-20-2016, 10:35 AM   #42
Chewie's Avatar
Ok, sorry for the dumb question... Wouldn't the wheel and steering wheel lock without the key in ignition? Sorry, new at flat towing. Thanks
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 03-20-2016, 10:40 AM   #43
Towing a Jeep Wrangler Xlimited
With the newer Jeep Wrangler the steering wheel does not lock.
KYSam is offline   Reply With Quote
Old 03-20-2016, 11:22 AM   #44
Jmsx2's Avatar
Originally Posted by Chewie View Post
Do you leave they ignition keys on "run"? I test towed my jeep last night and followed the owners manual but there was mention of the keys. I did leave the keys in the run position when I towed it. Thanks
Leave the key in the "Off" position. Once your set up you transfer case to neutral and put the transmission back in park turn the key all the way to "Off". Your steering wheel does not lock which is what you want for flat towing.
If your were to leave your key on while towing the odometer will register miles. You don't want that. Not to mention a possible dead battery.
Jeeps are so easy to flat tow. Enjoy the ride.
John & Janine
Pazzo the Maltese
2014 Georgetown 328 TSF
2013 Jeep Wrangler Rubicon (Toad)
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 03-20-2016, 11:45 AM   #45
Chewie's Avatar
Awesome, thanks for the help.
Old 03-20-2016, 08:30 PM   #46
As stated, Jeep quit locking the shell I the Wranglers around 2011 I think. Great toads! Love it.
Old 03-20-2016, 08:44 PM   #47
Taranwanderer's Avatar
Used to tow my YJ behind the truck before I got a trailer. 5 speed manual, just put the tranny in neutral and the t-case in 2-hi. If you put the t-case in neutral, it disconnected the running gear from the tranny and engine, but it locked the front and rear driveshafts together, which created more wear and tear. In 2 hi, it was just turning the rear driveshaft. But in newer Jeeps (JKs) I'm guessing things have changed quite a bit. YJs and TJs are my knowledge base...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 03-22-2016, 07:25 PM   #48
Jmsx2's Avatar
JK's are extremely easy to flat tow. Turn ignition on (don't start). Put trans into neutral then transfer case to neutral. Start up Jeep and put in drive for 7 seconds. Do the same for reverse to confirm no movement. Turn off and put Trans back into park leaving transfer case in neutral. Take key out of ignition and hook up Coach. It's that simple.
I've put thousands of flat tow miles on my 2013 JK Rubicon. No issues at all.
John & Janine
Pazzo the Maltese
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 03-22-2016, 07:49 PM   #49
I think all of Canada & all United States except Missouri require braking on the towed vehicile
hardoiler is offline   Reply With Quote
towing
