05-21-2015, 01:55 PM
Towing vehicle behind FR3
Can anyone give suggestions on what type or make of vehicle would be good to tow behind a FR3 30DS? I am considering purchasing a vehicle for our motorhome. Any suggestions would be appreciated. Also any type of problems I would be facing in the distant future. Thanks for all of the replies in the past to my post.
05-21-2015, 03:38 PM
Certified Curmudgeon
The answer depends on what you want the toad for. Im sure you will hear from the mud slinger crowd on this one. Like a buckboard ride, high cost of operation? Then Jeep is for you. Want a grocery getter and eco tour vehicle? We chose the Fortwo. Then there is the Fiat 500 and Honda Fit. Maybe a 2014 or older CRV. If you like a stick, the field opens wide up. In that case, I'd look at a Subaru.
The list goes on and on.
Do consider that almost anything you flat tow will need a brake system at about $1000.
Lots of posts on that.
Want to dolly tow? You can tow just about anything on a dolly.
You can pull a trailer too. That Bimmer Z4 will fit on that!
Bottom line is you really did not give enough info to make a reasonable recommendation.
Soooo at this point, the biggest problem you will face in the future is making a decision.
Mike Dropped
05-21-2015, 06:20 PM
I tow a 2012 Hyundai Veloster, manual. Only weighs 2,400lbs, seats 4, and gets 38 MPG. I can't even tell it's back there.
I do want to get a jeep though. I love off-roading and that's not an option in a Veloster.
2015 FR3 30DS
05-21-2015, 06:27 PM
HAPPY WHEN RV'ING
You just need to keep in mind, other than what Duckogram listed, is that whatever you choose as a "toad" you'll either need a tow dolly, trailer, or tow bar & base plate. Most will also need a wiring kit for turn signals & brake lights that wire into the tow plug.
The 30DS has a towing capacity of 5000#. That weight also needs to be figured in on the total overall weight capacity of the coach
We chose a 2014 Honda CRV. Can't even feel it behind us.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
05-21-2015, 07:31 PM
We flat tow a 2013 ford focus with push button start. I mentioned the push button because it has a little different set up for towing. The only draw back to it is no towing over 70 mph if that is what you do. We keep it at 65, and honestly I can't even feel it. We do keep the back up camera on so I can see it if I pass someone I can see when I clear them. Just read the owners manual or hit Google. Oh and because you don't have battery connection during tow, no mileage racks up.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
05-21-2015, 08:00 PM
We tow a 2014 5 speed Fiat sport. It too racks up no miles when ignition switch is off. No key needed in the ignition because the steering wheel doesn't lock. You don't know it's even back there.
05-21-2015, 08:58 PM
We flat tow a 2014 Jeep Wrangler so we can
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
05-21-2015, 10:34 PM
Jeep Wrangler all the way!!! (OlllllllO)
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
05-22-2015, 11:29 AM
Fiat toad
We also tow a 5 speed manual Fiat 500 - easy to hitch, easy to squeeze into small campsites, easy to run around & see stuff.
05-24-2015, 03:55 AM
We flat tow a Fiat 500L with manual trans using a Blue Ox tow system. It's a light vehicle, and is good on gas.
05-24-2015, 03:58 AM
We bought a 2014 jeep tow.. sold it after one year... miserable to drive and worst than the motor home in a crosswind... it was doing 16 per 100 km. Lol almost as bad as the motor home. Anyways we just traded it in for a 2013 crv... really enjoying that 8.2 around town .
05-24-2015, 09:49 PM
05-25-2015, 10:30 AM
I use a acme tow dolly and pull my 2015 Honda CRV. You hardly know it's there
05-26-2015, 07:27 PM
Tinkerer and Putterer
Since you're looking for a Jeep I assume you're fine with a manual? Even with a manual I believe that the newer Jeeps have a transfer case that will not spin when the trans and tcase are in neutral but you might want to consider that trailer. Someone up on the newer Jeeps can probably put you straight on that one. I am from the CJ / Wrangler generation so I'm sure that my info is out of date.
Jeep Parts, Jeep Accessories & Jeep Soft Tops From The Jeep Parts Experts - Quadratec
That being said we flat tow a 2012 Ford Escape w/ a 5 speed. It pulls 30 MPG and can do some beach combing but I wouldn't take it rock crawling or mudding that's for sure. It is not a trail machine by any stretch of the imagination. My Ford weighs about as much as a TJ (3500 lbs empty, ~3650 with a full tank). I don't notice it back there except when I hit the mountains. Then I lose 5 mph on the grades.
The new Escapes cannot be flat towed according to Ford and I wouldn't even think of trying to go off the pavement with one so if you're stuck on new and trail riding then a jeep and a second toolbox are in your future.
