Old 02-16-2018, 10:03 PM   #1
TP Holder in FR3 29DS
We have a 2018 FR3 29DS. We have no where to hold the TP. Where should it be? It is missing? Does anyone know where I should continue to look? Any and all help is VERY HELPFUL. TYIA
Mtncampers is offline   Reply With Quote
Old 02-16-2018, 10:17 PM   #2
PPST Wannabe
kenandterry's Avatar
How about a stand-alone? We have one like this to include extra rolls.
https://www.google.com/search?q=toil...obile&ie=UTF-8
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 02-16-2018, 10:34 PM   #3
GT Traveler's Avatar
Our TP holder was not mounted when we got our coach. You are correct that there is no real good spot to mount. We went with the stand alone version like Ken mentioned and have no trouble with it.
Mark & Connie
2020 GT5 31R5
2006 GMC Canyon (Toad)
GT Traveler is offline   Reply With Quote
Old 02-16-2018, 11:00 PM   #4
They leave it off so you can put it where it is most convenient. I found a wall stud below a hook that is on the right wall as you're sitting on the toilet. The screws they gave me with the toilet paper dispenser we're too long so I used shorter wood screws and it worked just fine. I have a 2018 fr3 30ds.
jimlitwin is offline   Reply With Quote
Old 02-16-2018, 11:02 PM   #5
You can feel where the wall studs are where the thin wood is very solid and does not move. But I was able to screw into the wood where the wall stud wasn't as well with no problems
Old 02-17-2018, 02:10 PM   #6
After ours pulled out of the wall, I picked up a free-standing one that holds extra rolls as well.
Linda
Solera 24R
Washington
PNWTraveler is offline   Reply With Quote
Old 02-17-2018, 02:25 PM   #7
Making screws hold in that thin paneling
It's really annoying when screws pull right out of that thin paneling. Put a 3/16" bit in your drill and drill out the hole. Advance the bit SLOWLY. You don't want to splinter out the back of the hole--that only makes things weaker.
Then press or tap the small size anchor in this set into the hole. As you drive the screw into the anchor, its legs expand to wedge it firmly in place. We've remounted light fixtures near the bed that were easy to knock loose. This is a better option than making more holes.
Larry
Larry-NC is online now   Reply With Quote
Old 02-17-2018, 02:54 PM   #8
Where to mount TP roller
Sometimes the best spot is on the inside of a cabinet door. Consider this if there is a cabinet door reachable when you are seated upon the throne.
We've mounted our paper towel holder on the inside of the cabinet door beneath the kitchen sink. There was no other place where wouldn't have run into it. We got the simplest we could find, essentially a U-shaped piece of stainless steel with bosses stamped on the inside of each end. I drilled a new mounting hole at each end, right at the bend, so the screws would enter the cabinet door frame, not the thin recessed panel in the door.
Larry
Old 02-17-2018, 06:38 PM   #9
Found them
Thanks to everyone for the great ideas. We have had our MH for a week so still finding things. Well today, DH found the side holders for the TP. We see that you can modify things to your personal tastes. Our first trip out is next Wed. for 5 nights. Yippee
Old 02-17-2018, 07:26 PM   #10
Luannr's Avatar
We have a 2017 29ds, and mounted the toilet paper holder under the top of the open shelf, seems to work good for us.
Luannr is offline   Reply With Quote
fr3
