Old 07-22-2015, 06:04 PM   #1
Mark
Transfer switch location?
Hello friends! I have a 2016 FR3 30DS, less than six weeks old and apparently my transfer switch is bad according to the tech on their helpline. Does anyone know where it's located on this model, the engineers in charge of hiding stuff have done a good job on this one LOL.
Mark
marky411 is offline   Reply With Quote
Old 07-22-2015, 06:41 PM   #2
fonzie's Avatar
Follow your shore power supply inside and first box it goes in, should be it........or you might not have a transfer switch...see thread below. Also in FR3 features it does not mention transfer switch.
2015 FR3 30DS surge protector
http://www.forestriverinc.com/produc...age=5049&Tab=1
ELECTRICAL & PLUMBING
4.0 kW Onan® Gas Generator
2 Deep Cycle House Batteries w/ ABS Cover
Battery Disconnect Switch
Emergency Start Switch
Black Tank Flush
VIEW MORE
Outside Shower
30 amp Power Cord w/ Storage Compartment
6 Gallon Gas/Electric Water Heater
Arctic Pack System (Heated Holding Tanks)
35,000 BTU Furnace
KING JACK® Power HDTV Antenna w/ Surelock Signal Meter
12V Prewire for Power Roof Vents
Fonzie
Old 07-22-2015, 07:34 PM   #3
My understanding is that the FR3 doesn't have a transfer switch to have power from the generation to the coach you have to plug it in the outlet in the compartment with the power cord.
Tom & Cheryl
Champaign,Il
2016 Georgetown 369
blacktom is offline   Reply With Quote
Old 07-22-2015, 07:38 PM   #4
Technorick's Avatar
My 2014 has no transfer switch. It plugs into itself ( the generator female outlet is located in the power bay). If you have a female generator plug in your power bay then you don't have a transfer switch.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 07-22-2015, 08:34 PM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
If you have an outlet plug in the compartment where your cord is, you do not have a transfer switch. Unless they've made a change, FR3's do not have one. My 2014 did not. I added an auto transfer, 30 amp surge protector, and an inverter. All are working great!
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 07-22-2015, 08:42 PM   #6
Pardon my ignorance, but after you start the generator, it takes like 10 seconds before you hear a beep (I think from the microwave) when the 120v is turned on. What switch is that? I thought that was the/a transfer switch. I'm new to RVs, so feel free to correct me. :-)
KansasFR3 is offline   Reply With Quote
Old 07-22-2015, 08:52 PM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
Having your 30 amp cord plugged in, It will take a few seconds after you start the generator to hear your microwave beep. It's not from a transfer switch (I'm referring to FR3's here). It's just your system kicking in normally.
Old 07-22-2015, 08:53 PM   #8
Thanks drivmsafe for 411.
Old 07-22-2015, 09:50 PM   #9
Mark
transfer switch
I appreciate the responses from everyone! It's becoming apparent that I do not have a transfer switch in my 2016 FR3. As you can guess I'm very new to this. My RV is currently in front of my house, haven't even been on a trip yet, and yesterday with the generator on, all of a sudden I lost power to the outlets, AC, satellite, etc. The tech on the coach-net service line had me turn the generator reset button on and off, turn the main breakers on and off and when power did not come back on, told me I probably have a bad transfer switch and would need to take it in for warranty service. Very frustrating to say the least. I guess I'll be finding my nearest Forest River service center. AAAARGH!
Mark
Old 07-22-2015, 10:08 PM   #10
Bus Driver
Deaver's Avatar
There is an additional Generator Breaker mounted to the right side on the Generator Control Panel that has the start switch on the Generator itself. Open the Generator compartment, Remove the Generator cover, Look between the oil fill and the start switch. It is on the side and looks like a household light switch but black.
2012 Forest River Forester 25651S - The Magic Bus
Just trying to be the person my Dog thinks I am
Deaver is offline   Reply With Quote
cat, location, transfer switch
« Upscale FR3? | TPMS »
