Old 09-01-2015, 06:16 PM   #1
twojump36's Avatar
Transmission / Shifting issues
Hey guys,
We bought the 2015 30 DS about 2-months ago and have had it out a couple times... so far we really like the coach, but I have a couple concerns.
This is my first MH and my first Ford product...
So my question is on the V10 Triton and Transmission...
I've driven this thing about 300 miles total. 100 miles not towing anything and 200 miles towing my Jeep.
When I drive it normally (not towing) I just put it in D and go... The transmission seems to really run up the rpm's before it shifts into the next gear.... I'm driving it pretty gently here and not by any means putting my foot into it. 1st and 2nd gears are pretty much the same, but once into 3rd it really rev's out before it goes into 4th... like 3200 rpms.
When I towed my jeep, I used the tow / haul mode button and put it in D and went normally. The tranny runs the engine to about 3500 before it will shift.... in 1st, 2nd and 3rd... I'm not sure it's normal. I'm a "car" guy and have a few hot rods or classic's but not one of them shift like this RV..
I'm about waiting for the motor to fly thru the floor and sometimes have to lift the accelerator before it will go to the next gear...
I almost don't have the will power to leave my foot in it to see if it will eventually shift.
Also in Tow / Haul mode and in D... once I crest a hill and start down the other side, the coach will normally pick up some speed... if you begin to brake for a corner or whatever, the tranny will down shift and fun out at about 4500 rpms.... it will not shift up or out of whatever gear that is until we hit the bottom of the grade....
This to me seems very hard on the motor or transmission... it is strange and I don't want to tear this thing up. 4500 rpm seems very extreme.
I will add that neither the transmission temp or engine temp rises when this happens.
Is this normal?...
Has anyone else experienced this?
twojump36 is offline   Reply With Quote
Old 09-01-2015, 07:12 PM   #2
Bobb36's Avatar
Everything sounds normal to me working the way it was designed.
I personally don't use the tow/haul mode when I tow my jeep which is all the time now except to go get gas.(don't like the downshift design in the tow/haul mode)
The V-10 Loves the high RPM's
we have just under 24,000 on are FR3 DS-30
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 09-01-2015, 11:06 PM   #3
twojump36's Avatar
So you've experienced the same thing...?
I'm not sure how an engine that is a production model can stay together through all those rpm's
Old 09-01-2015, 11:44 PM   #4
The Triton V10 does not get peak torque until over 3000 rpm, and peak horsepower until over 4000. It is working as designed.
Jeff and Elaine
2011 Berkshire 390QS
2 Lab Dogs-Eros and Star
1 Cockatiel-Lucky
dogsgocamping is offline   Reply With Quote
Old 09-02-2015, 12:20 AM   #5
Retired guy
Big Dog 1's Avatar
Yup, completely normal
Big Dog 1 is offline   Reply With Quote
Old 09-02-2015, 06:46 AM   #6
No worries. Let that cat purr and lay on it. The V10 is meant to be wound up. Just make sure your dog house is tighten down so your not hearing TOO much engine noise. I know we picked up our '15 30DS, and it was pretty loud. Tightening down the hatches makes it a little more bareable once the seals are compressed. The Tow/Haul mode provides some engine braking when going down some grades, hence the upshift once you crest the hill. Just drive it like you stole it and enjoy!
KansasFR3 is offline   Reply With Quote
Old 09-02-2015, 10:26 AM   #7
twojump36's Avatar
I really like the motorhome.... after a few problems got fixed, it really is what we wanted and fits our lifestyle and family's needs.
I do not like the transmission... but I guess I'll just drive it the way it is for now. I talked to a Ford Tech in Salem Oregon near where I live and he said I could bring it in and maybe they have an update for the tranny or they could change shift point programing in the ECU...
I like the engine braking on the down-hills but 4500 rpm's seems like it's going to come apart.
I drove a NASCAR car once and it's the only thing that you needed to run up that high I've ever experienced...
FYI I only got 5.76 mpg on the trip towing the Jeep... lots of hills over here in Oregon... seems like it's up hill both ways!
Looking forward to a few more trips before we put it away for the winter.
Old 09-02-2015, 12:27 PM   #8
Concur with everyone that it is working as designed. This engine has been around over 10 years and the bugs have been long worked out. Regarding your fluid temps: don't trust the factory gauges - they are designed to only show increased temperatures when things get really hot. Try this add on gauge to read the real temperatures to 1 as reported by the engine computer. http://tinyurl.com/qjmn5xz Easy to install
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is online now   Reply With Quote
Old 09-02-2015, 12:47 PM   #9
Former Full Timer
Duckogram's Avatar
5.76 is way too low. I just returned from a 10,000 mi trip from S Fla to Coeur d'Alene via NM, Moab, Hells Canyon and back through Glacier, Rocky Mtn and Chicago. I average over 8. I had a CEL come on and fuel econ was dismal like yours but it was a stuck valve in the evap canister. Fixed in TX and mpg back up. I get reasonable economy by driving at 60 - 63 mph, Slow starts, no cruise control unless on flat roads with favorable winds and no tow/haul (yes I tow).
The tow haul mode programming disables O/D.
There is another thread in this section where tuners are being discussed. All evidence indicates that a tuner will help you with your concern (which I share).
Spent a couple of weeks in your Ainsworth State Park last year. Loved it!
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 09-02-2015, 12:59 PM   #10
BobHanke's Avatar
Sounds very normal. The tranny senses when you are going downhill and what cruise control is set for. I like to drop out of cruise going up hills as I hate that engine winding up past 4000. However, you really need the tow/haul mode when coming down steep slopes or you risk brake damage. You will notice less down shifting going up hills as your fuel gets used. I only fill the tank all the way when I need the ballast while fighting side winds. Same goes for gray and black water tanks.
BobHanke is offline   Reply With Quote
