Old 11-26-2017, 10:03 AM   #1
Turning off propane question
Have noticed that when I turn off the propane at the tank it doesn’t completely close. I can turn the stove on and low flame will continue to run indefinitely.
What’s the easiest fix for this? I hand tightened it is much as I could but figured using a wrench would be a bad idea.
CSroo is offline   Reply With Quote
Old 11-26-2017, 10:18 AM   #2
PPST Wannabe
kenandterry's Avatar
It may take awhile to purge all the gas from the lines running from the onboard tank....enough to keep a small flame running for a bit.
Does yours run longer than 5-10 minutes?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 11-26-2017, 10:20 AM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
The stove can in fact burn for a long time with the residual gas left in the line but, if you do have a leaking valve on the tank have it checked out and replaced asap.
Two things in an rv where I don't cut corners, electric and propane.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-26-2017, 11:50 AM   #4
Thanks. Ran it for a good 10 but will try again today to ensure no leak
Appreciate it
Old 11-26-2017, 02:15 PM   #5
Both tanks turned off?
Are both tanks turned off?
I would make a dish soap and water mixture, remove the hose fitting from the tank on both tanks and drizzle some soap mixture into the valves. If you got bubbles, you have a leak.
Try turning the valve a bit more and see if it stops. If so, then close them harder. If not, use the propane up and have the tank replaced or have the valve replaced based on cost.
You can not build up a dangerous situation with a leaking tank in the open air.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 11-26-2017, 04:35 PM   #6
I think there is a check valve in the tank valve that should cut the gas off.
You can remove the hose with the valve on and no gas would flow as the check valve shuts it off therefore you can not tell if the valve is faulty or not. You would have to disconnect the hose downstream from the tank to check this out.
hilfikerkg is offline   Reply With Quote
Old 11-26-2017, 04:45 PM   #7
DavidBo's Avatar
If you do suspect a leaky tank shutoff valve, by all means leave that tank disconnected until you can get it taken care of. Cypressloser is absolutely correct, there's zero tolerance for propane problems.
DavidBo is offline   Reply With Quote
Old 11-26-2017, 04:53 PM   #8
PPST Wannabe
People....
This is posted under the forum heading of FR3 motorhomes. There is only one propane tank attached to the chassis on motorhomes....unles CSroo posted under the wrong heading.
Propane cylinders can be the disposable green ones for Coleman burners, and even the cylinders found in Travel Trailers and 5th Wheels.
https://rvshare.com/blog/the-ultimat...ing-or-buying/
Ken and Terry
Old 11-26-2017, 05:08 PM   #9
Send a message via MSN to Tiggerdad
If the valve is leaking through why would he leave the tank disconnected? Doing so allows propane to vent to the atmosphere. Not a good thing.
Tiggerdad is offline   Reply With Quote
Old 11-26-2017, 05:16 PM   #10
DavidBo's Avatar
Originally Posted by kenandterry View Post
People....
Shoot, I usually check that too! You mean not everyone has a rig just like mine?
propane
