Old 02-18-2017, 02:16 PM   #1
Tv and plug in bathroom and under tv cabinet not working
Tried to click in gfi....no luck and just replaced it.Breaker ok,is there another fuse,etc that I am missing?
lazbo is offline   Reply With Quote
Old 02-18-2017, 02:33 PM   #2
MacGumbo's Avatar
It could be a loose connection at one of the receptacles before the TV and bathroom. Manufacturers will use the back of one receptacle as a junctions to the next and sometimes a wire may come loose. You might want to check the working one previous to those receptacles for a loose wire.
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
MacGumbo is offline   Reply With Quote
Old 02-18-2017, 02:52 PM   #3
The gfi clicked in and is working now...makes me think it might be a loose wire
Old 02-18-2017, 03:06 PM   #4
always travel with a spare gfi
Combatcoal is offline   Reply With Quote
Old 02-18-2017, 03:41 PM   #5
All my GFCI outlets weren't working the other day. I tried hitting the reset on the plug and they didn't work. Checked the breaker and it wasn't tripped. They started working after I turned the breaker off and back on so who knows.
ronj82 is offline   Reply With Quote
Old 02-19-2017, 09:23 PM   #6
I did check the one under the bed and behind the bedroom tv and found that two wires were completely coming out of the bayonet type holder...so went to Lowes and bought another plug that I screwed the wise to instead of the cheap plug...fixed my problem as you said check for a loose wire...with all the jumping around the motorhome gets no wonder they were coming out...thanks for getting me to look there
Old 02-20-2017, 03:31 PM   #7
MacGumbo's Avatar
No problem. Glad I could help.
roo
