Old 03-25-2017, 09:58 PM   #1
Tv in kitchen not working
I'm sure it is something stupid but what?
We are hooked up to cable but no sign of channels. Did a scan still nothing ..
colourful64 is offline   Reply With Quote
Old 03-25-2017, 10:10 PM   #2
Who Dares, Wins
doc73's Avatar
Check behind the wall plates and. Make sure the wires are actually hooked up. None of the wires in mine have ever been totally right. Also do you have TV anywhere else before tearing into things?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 03-26-2017, 12:54 AM   #3
It's all hooked up...nope no tv lol
Old 03-26-2017, 04:03 AM   #4
wayne and sherry's Avatar
If your looking to watch local stations, make sure the signal booster is on. If your hooked up to shore cable make sure the booster is off.
wayne and sherry is offline   Reply With Quote
Old 03-26-2017, 09:48 AM   #5
We are hooked to cable .. where's the signal booster ? We had this two years now and this is the first time hooked to cable
Old 03-26-2017, 09:51 AM   #6
SeaDog's Avatar
Look at the wall plate by the main TV where the cable comes out there may be a tiny light there and a switch. if the light is lit turn the switch to the other position. Other then that as others have said it may be how the rig was wired or not wried you can pull the wall plate to see what you have
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-26-2017, 09:52 AM   #7
Ok thanks will try that
Old 03-26-2017, 09:54 AM   #8
Who Dares, Wins
doc73's Avatar
I am not sure if you actually answered my questions, but do you have TV anywhere else in the camper or is all out? Also, is the TV set to use a cable connection my antenna? I know our tv needs to be changed in the menu to use either antena or cable then a scan run.
2015 ChevyHD D-Max
Old 03-26-2017, 09:57 AM   #9
SeaDog's Avatar
X2 What Doc73 said about the TV menu and ensuring it is switched to Cable
Retired Navy
Old 03-26-2017, 09:58 AM   #10
The menu doesn't have a catv option and I have no cable in any of the three tvs
