I cant speak specifically to your RV/television, bit I did replace our Furrion television with a Samsung. Generally speaking, the mounts are all universal. In other words, the holes in the bracket that you use right now on the bad tv, may not be the same holes on the new tv, but there will be holes in the bracket that do fit any tv you buy.
The only issue we came across, was the Samsung holes on the back of the tv, required a longer bolt than what the Furrion tv needed. The book that comes with the tv will tell you what bolts you need, and you can get them at Lowes/Home Depot/hardware store/etc. Usually a standard M6 or M8 bolt (if my memory is working), and then you just need to buy the appropriate length.
Thats the long way of saying it really shouldnt be an issue replacing your tv.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
