Old 12-15-2014, 12:07 PM   #1
FreddieMac's Avatar
Tv while driving
My wife and I are exploring our first MH. The FR3 is very high on our list. The big thing we cannot find is if the TV will operate while driving without the generator. Any info would be helpful.
FreddieMac is offline   Reply With Quote
Old 12-15-2014, 01:10 PM   #2
leisurelarry's Avatar
Yes indeed it will operate while driving as long as you have your generator running. Using the amplified rooftop antenna may or may not bring in a broadcast signal depending on your location. However watching DVDs is a sure thing.
leisurelarry is offline   Reply With Quote
Old 12-15-2014, 01:26 PM   #3
KennyGolub's Avatar
I could be wrong, but I think your inverter could handle the TV until the batteries died. Then your generator may kick in automatically if the FR is setup with that.
KennyGolub is offline   Reply With Quote
Old 12-15-2014, 01:41 PM   #4
FreddieMac's Avatar
The main thing for us is the DVD for the little ones. I would also like to give them the option to play their game system as we go down the road.
Old 12-15-2014, 02:35 PM   #5
I believe you are referring to the 12 volt TV of MH so you are either going to have to run generator, use 12v inverter or have one VERY!!!! long extension cord to plug shore power cord into.If you are going to use game system it would be easiest to just run gen set while driving.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-15-2014, 03:05 PM   #6
Kaadk's Avatar
If you're going to run a game system, you'll probably need 110V power. This will be either from an inverter (powered by the batteries) or from running the generator.
If you have a 12v TV, then yep, you can run it without the generator. It runs off the batteries. If you don't have a 12v TV, then like the game system, you need either use an inverter or to run the generator.
Old 12-15-2014, 03:33 PM   #7
FreddieMac's Avatar
Sounds like running the gen for 110 power is the norm.
Old 12-15-2014, 09:28 PM   #8
Bobb36's Avatar
to answer you original question, no the TV will NOT work in a FR3 without the generator running
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 12-15-2014, 09:58 PM   #9
FreddieMac's Avatar
Thanks for the answer
Old 12-16-2014, 01:18 PM   #10
HAPPY WHEN RV'ING
drivmsafe's Avatar
Installing an inverter is your best bet.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
