Old 09-14-2016, 04:30 PM   #1
Lexi2007's Avatar
Two New Head Scratches for these Newbies
Two questions, why would gray water all of a sudden drain slowly, probably 50% slower than before. Nothing other than sink water or shower water goes in and we've been very careful about what goes into the black water tank too. Also, the sewer connection at one RV parks was way below ground,,,maybe 4 inches. Cheap handling fix? The people at the office had no suggestions or fixes.
Lexi2007 is offline   Reply With Quote
Old 09-14-2016, 04:37 PM   #2
First thing that comes to mind is a plugged roof vent.
Old 09-14-2016, 04:37 PM   #3
Ford Idaho's Avatar
For the gray tank.
Plastic slug from when the factory cut the hole for the vent or drain may be caught in the drain valve.
For the drain hose.
A big rock, use it to hold your hose drain end in the hole.
Yes I have done it, the rock was holding the cap on the drain when I first saw it.
Old 09-14-2016, 04:43 PM   #4
jk510's Avatar
Cheap Handling Fix (CHF) is a sort of modification made to Ford based motor homes. Due a search for either terms and you will find out more than you ever wanted to know. You don't have a signature line yet so I don't know what your RV is.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 09-14-2016, 06:50 PM   #5
Lexi2007's Avatar
Lol
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Old 09-14-2016, 07:10 PM   #6
World Wide Wanderer
wahoonc's Avatar
Grey water issue... sounds like the gray dump valve is partially blocked by some construction debris or the valve isn't opening all the way. Make sure the pull handle is screwed all the way in. Second guess is a blocked vent stack or purge valve.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-15-2016, 09:24 PM   #7
You may be able to put one of those cameras up into the pipe and check it out. They use them in automotive repair and I think there is one available at Harbor Freight Tools. Maybe you can borrow one and see if you can see anything.
ProfChuck is offline   Reply With Quote
newbie
