Old 08-15-2016, 06:30 AM   #1
Unit A/C or dash when driving?
2016 FR3 30 DS: Walk through tech said to use unit a/c when driving as it keeps battery's charged and sales guy that knows everything - yet doesn't own an rv - said use dash a/c as that cools plenty. What are your opinions? Thanks!
KevandSyl is offline   Reply With Quote
Old 08-15-2016, 07:06 AM   #2
IF the dash unit has enough in a given situation, just use it. If it isn't enough, use the generator and the roof unit as well. That is what most do. The batteries should be charged by the alternator when the engine is running.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 08-15-2016, 07:08 AM   #3
ilmor's Avatar
Sales guy was correct. Tech guy needs training.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-15-2016, 09:41 AM   #4
waiter21's Avatar
You shouldn't need to run the generator to keep the batteries charged while cruising down the highway...
If the Dash AC won't keep up,, crank up the genny and turn on the roof unit. Make sure all the ceiling vents are closed, and also run the dash AC in MAX.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-15-2016, 09:56 AM   #5
We typically run the genset when driving. Not necessarily to charge the batteries, but more so for running the house AC. Run it when you need it, though I think you'll find the dash AC lacking.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 08-15-2016, 10:09 AM   #6
Cigarman's Avatar
As everyone else has said, when the dash isn't enough run the unit AC. We do it on and off depending on the kids level of whining about being hot, then in 5 minutes they are cold so no winning for me. Running the genny isn't needed to charge the house batteries when your driving.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
Cigarman is offline   Reply With Quote
Old 08-15-2016, 10:10 AM   #7
World Wide Wanderer
wahoonc's Avatar
Both...
I run the unit A/C if the temps are above 80, especially if it is sunny. We almost always have the dash A/C going too.
The engine alternator charges the coach and chassis batteries. The generator only charges the coach batteries.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 08-15-2016, 11:59 AM   #8
HAPPY WHEN RV'ING
drivmsafe's Avatar
Running the dash AC on max should only be done until the air coming from the dash vents is cool enough. Then turn the switch to AC or norm.. Running on max all the time will cause icing on the lines. Same process as running a refrigerator/freezer on too cold of a setting. Keep in mind that an air conditioners function is not to cool the cab but to remove warm air from a vehicle.
I do agree that if the dash air is not cooling you enough (especially when having other passengers), run the gen. and turn on the house air.
If it's just the wife and I, we'll sometime hang a blanket from the overhead bunk to keep as much of the dash air in the front area. So far has worked well.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 08-15-2016, 12:14 PM   #9
Originally Posted by wahoonc View Post
Both...
Aaron
Nope. Generator, or more accurately stated, converter/charger on the FR3 does charge the chassis battery.
cucamelsmd15 is offline   Reply With Quote
Old 08-15-2016, 12:52 PM   #10
Hanging a blanket or the privacy curtain to keep dash cooled air in the cab area is a great idea.Usually just the two of us and our dog, who rides between us. Now why didn't I think of that? LOL
Lazy Day is offline   Reply With Quote
