Old 02-17-2015, 11:06 AM   #1
Using 50 AMP
My RVing experience started in May of 2014 when I picked up my 30DS from a dealer in Indiana. Since that time twice I've had electrical problems relating to the power pedestal at RV parks. In both instanced while connected to the 30 AMP plugs the power has tripped off from the pedestal circuit breakers. I know the RV was not pulling more than 30 amps in either instance. Last night here in the RV park in Pensacola a neighbor lost power when the 30 amp circuit breaker on his pedestal failed. Fortunately he had a 50 to 30 amp adapter and we were able to connect to the 50 amp side and power him up. My standard procedure now is to plug my unit into the 50 amp side using the 50 to 30 adapter if there is 50 amp service at the RV park. I also have an inline surge suppressor that I use whenever plugged into outside power.
z3406 is offline   Reply With Quote
Old 02-17-2015, 11:57 AM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Most have had that experience. I once had to use a extension cord to reach the other pole. Good thing no one was their. Now I trip, set, trip, set, a couple of times before using and with that I will use 50amp if available. The 30s are normally so loose, or weak, I often leave a note or talk with the CG Mgr. about the need to replace. All that being said I still have a meter plugged inn to monitor the running voltage. Just another quick check to the control board daily checks.
donanddona is offline   Reply With Quote
Old 02-17-2015, 12:28 PM   #3
Witch Doctor's Avatar
X's 2 on that I use 50 all the time and drop it to 30. Your 30 in the trailer is your protector.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-09-2015, 09:08 AM   #4
Can you use a 30 amp surge protector on a 50 amp outlet with the adapter cable?
jbutch is offline   Reply With Quote
Old 03-09-2015, 09:11 AM   #5
B and B's Avatar
I would rather burn up a dogbone than my surge suppressor connector. Same here.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-09-2015, 09:12 AM   #6
Yep do it all the time hook it to the dog bone then hook your trailer plug in as normal.
Old 03-09-2015, 09:34 AM   #7
geotex1's Avatar
I agree and learned long ago that 50A to 30A adapters are must-haves! Plenty of pedestals I've hooked to were downright dangerous with how worn the 30A and 15/20A receptacles were, but the 50A practically new!
geotex1 is offline   Reply With Quote
Old 03-09-2015, 09:55 AM   #8
vinmaker's Avatar
So true. I hate it when there is no 50amp option.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
50 amp
