Old 11-25-2014, 11:27 AM   #11
deannelsonrn's Avatar
Did you have to remove the core from the first ones?
deannelsonrn is offline   Reply With Quote
Old 11-25-2014, 05:42 PM   #12
You do not have to remove the old valve cores when installing an extension
z3406 is offline   Reply With Quote
Old 12-04-2014, 11:42 AM   #13
Harleyreb's Avatar
I did not like the flexible valve extenders, nor the metal clip they used to keep them from flopping around, so I bought the DuallyValve DL3FC solid extenders and had a local tire shop install them. Then I added the Tire-SafeGuard TPMS system for piece of mind. It will monitor the FR3 tires, plus the toad.
2015 FR3 30DS
2014 Jeep Cherokee Latitude
2017 Jeep Wrangler
Harleyreb is offline   Reply With Quote
Old 12-04-2014, 09:42 PM   #14
Brewster McFrisk's Avatar
I don't like extenders if I don't have to have them, potential leak. You can't get around not having them on the dollies inside tire but the outside tire I removed the cover and cut the holes big enough to get a Guage and air nozzle on. Fronts were OK. Cheap fix! Looks great
Brewster McFrisk is offline   Reply With Quote
