Old 07-07-2015, 12:16 AM   #11
leisurelarry's Avatar
You must remove the anode rod from the bottom of the tank by unscrewing it with a socket. Then insert the hot water tank cleaning tool attached to a water hose into the opening and spray it out moving the cleaning tool around. All of the sediment is on the bottom of the tank so aiming the tip of the tool towards the bottom of the tank is the way to go. The sediment and water will flow out. You need to continue spraying until you get no more sediment flowing out.
leisurelarry is offline   Reply With Quote
Old 07-07-2015, 12:19 AM   #12
You can get a cleaning tool from Walmart, Amazon, Camping World or any RV parts house. They are about $7-$8.
Old 07-07-2015, 12:25 AM   #13
Name:	ImageUploadedByForest River Forums1436246739.590947.jpg
heater, water, water heater
