Old 10-25-2017, 11:51 AM   #1
Orider's Avatar
Water Heater, Faucet and Toilet slow or no water
For those that may have found that the faucets and probably the toilet get plugged up with a WHITE sediment....here is the cause and the answer. Take out the ANODE ROD from the Water Heater, clean the tank out GOOD, and then replace the rod. Here is a pic of the BAD one and then the GOOD one. Check and change it once a year. When you buy one....get 2, one for a spare.
Orider is offline   Reply With Quote
Old 10-25-2017, 12:12 PM   #2
Yes that is the Cause of the "White Crud" but installing a New one just Helps FEED the Cause! The one you show has Plenty of LIFE left! Installing a New Rod is just "Fresh Meat"! Youroo!!
Old 10-26-2017, 08:53 AM   #3
I am not sure I understand. Basically an anode rod dissolves, an old one or a new one. They are both going to break down. Putting in a new one is the same as using the old one unless the old one is completely dissolved. If the old one is completely dissolved, I guess you do not have to worry about crud getting in your water lines but you might end up needing a new water heater.
One think to consider, always drain your water heater before opening your low point drains. That will help reduce pulling crud back into your fresh water lines.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
water heater, water, heater, faucet
