Old 04-14-2015, 01:11 PM   #1
water lines when you dewinterize
Can anyone tell me or shoot me a photo of the four water line valves when you dewinterize.
leogeo is offline   Reply With Quote
Old 04-14-2015, 01:13 PM   #2
ColoradoRick's Avatar
Do you mean the bypass valves that are right next to your water heater?
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-14-2015, 03:19 PM   #3
Yes. Behind the black access panel with the circle you unscrew there are 4 valves to various water lines. I am trying to figure out which way the valves are supposed to be set. Thanks
Old 04-14-2015, 03:20 PM   #4
The three valve handles for the water heater all need to be parallel to the ground. With the valves in this position you are ready to use your water heater.
When all valve handles are vertical, the water heater is in bypass.
KYSam is offline   Reply With Quote
Old 04-14-2015, 03:26 PM   #5
Go to this post and look at post 15.
http://www.forestriverforums.com/for...r-77970-2.html
The first picture shows the water heater valves, 3 of them. The other is for the water pump to select between the draft hose, to draw antifreeze into the system from a jug, or from the fresh water tank.
Old 04-14-2015, 05:54 PM   #6
Name:   Summer Position.jpg
Name:   Winter Position.jpg
water, winter, winterize
