Old 08-11-2014, 09:36 PM   #11
Motoring
grotto69's Avatar
Coming back from trip. AC on full as we were in Florida. Condensation from chassis AC was dripping into a channel in the dash and as we turned it would come on all sections of the bottom dash. Bin the center and both sides. Need to bring that in.
grotto69 is offline   Reply With Quote
Old 08-13-2014, 08:39 AM   #12
leakage
I believe that the water leak in my coach might have been from rain water collected on top of slide out- after retracting and driving coach, think the water may have leaked down the inside wall on floor.
Lfrazee is offline   Reply With Quote
Old 08-13-2014, 01:54 PM   #13
Motoring
grotto69's Avatar
If you think about it, anything that wants to nest up under the slide awning could when it's out. Might make for quite and adventure if you pulled in the slide and a racoon ended up inside the coach. I'm sure the same thing happens with water too.
Old 08-16-2014, 04:00 AM   #14
Landshark1's Avatar
I had the same thing happen with my FR3 30D. I found water puddled on the drivers side near the bathroom wall. The coach was parked on fairly level ground. I discovered that the water came through the backside of the pop out while in the retracted position. I then pushed out the pop out and found some water pooled on top. I then got up on the roof and noticed that the rain gutter on the left side of the coach had a small gap where the water was able to leak through. I ended up sealing the gap with some caulk, and it seems to have fixed the problem. Hope that helps.
Landshark1 is offline   Reply With Quote
water
