Old 10-01-2015, 07:07 PM   #1
Water overflow tube problem
Fresh water tank draining while driving or sitting on a slope. Has anyone added a P Trap or shut off valve to the overflow tube? Or are there other solutions to correct the problem? Any suggestions and photos of fix would help. Also is the overflow tube also used as a. Ent tube for the tank or can it be shut off after filling the tank. As always thanks for your quick responses and help.
Mr J is offline   Reply With Quote
Old 10-01-2015, 07:49 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
Thought FR took care of the siphon problem. You have a couple choices. You can put a loop in the clear overflow hose or add a "p" trap inline. Either will solve the problem.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 10-01-2015, 08:37 PM   #3
Thanks for the info. Will give it a try.
Old 10-01-2015, 08:55 PM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
I forgot to mention that I went with the p trap. I used 1/2" pvc. It's not pretty but, no more problem.
Old 10-02-2015, 04:40 PM   #5
KsWhoDat's Avatar
Hey drivmsafe, could you post a pic of the installed p trap?
thanks
Jim & Cyndi
2014 FR3 30DS
2005 Dodge Dakota 4WD
KsWhoDat is offline   Reply With Quote
Old 10-02-2015, 05:05 PM   #6
Electric Solution
We fitted an electric water valve in the overflow line taking the feed for it off the pump supply. This means that when the pump is switched on, water or air can flow as necessary. When the pump is switched off the valve closes and seals the tank. So you just have to remember to switch the pump on when you are filling the tank and off when you are travelling.
CAVEAT If you overfill the tank, you will get the top of the tank bulging upwards until it can be caught up on the slideout ram mechanism. The result is a large and horrible hole in the top of the tank and the tank wrenched past its restraining wood blocks in synchronisation with the movement of the slideout and multiple shouts of "Water everywhere!!""
Old Bookkeeper is offline   Reply With Quote
Old 10-02-2015, 05:32 PM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
It ain't pretty. Kinda hard for me to work in such a small space. Used 3/4" pvc.
Name:	ImageUploadedByForest River Forums1443825129.051810.jpg
ID:	90477Click image for larger version
Old 01-14-2016, 10:36 AM   #8
from Cali
RV Pilot's Avatar
Again finding this group has made a huge difference. I've had my tank siphon dry three times and thought I was going crazy.
2015 FR3 30DS
Central Coast of California
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
RV Pilot is offline   Reply With Quote
Old 01-14-2016, 10:36 AM   #9
from Cali
RV Pilot's Avatar
I just got back from the dealer telling them the situation. They looked at me like I was crazy!!
2015 FR3 30DS
2015 FR3 30DS
2014 Jeep Rubicon X
Old 01-14-2016, 12:02 PM   #10
Overflow
Well I fixed the problem with the water draining out. I took the overflow tube out and replaced it with a new longer one. Made a loop in it so the loop was above the water tank. Fixed the problem for around $4 for the new tube. Will post picture of the fix soon.
water
