Old 03-22-2016, 10:37 AM   #1
Water pressure gremlins
Hello,
Just the facts;
2015 FR 3 30 DS, 18,000 miles, original owner.
Water pressure in bathroom sink, hot AND cold and toilet very low, was normal.
Shower is fine.
Kitchen sink is fine
No difference with shore water or pump
Without shore water or the pump on, water still comes out, very little but still
Nothing new has been done, filters, screens or any work of any kind
Noticed water dripping/leaking from the passenger side wheelwell while doing predrive inspection
Any and all help will be appreciated
rubingo is offline   Reply With Quote
Old 03-22-2016, 11:25 AM   #2
Remove aerator, most likely has trash in it.
LDStaas is offline   Reply With Quote
Old 03-22-2016, 11:42 AM   #3
Thank you , what is that stuff? White plastic chips?
Old 03-22-2016, 11:47 AM   #4
Most likely debris from when they cut holes in the water tank. We all go through a couple of times of cleaning the aerator screens before it stops clogging.
And with regards to the water dripping in the wheel well, double check your water heater anode rod isn't leaking. I think mine was until I put some teflon tape on the threads. I need to double check again now we're done de-winterizing.
KansasFR3 is offline   Reply With Quote
Old 03-22-2016, 11:54 AM   #5
yay
Thank you SO much, I will check that also.
Old 03-22-2016, 02:11 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
In reference to the leaking water around the wheel well on passenger side, you might also want to make sure it's not the overflow tube from your fresh water tank. Early models had a siphon problem when tank is close to full. If that is the problem, an easy fix is to put a loop in the clear line or, like I did, add a "p" trap using pvc fittings. There are other posts on this subject.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
pressure, water
