Old 07-18-2018, 11:00 AM   #1
Water pump
Pump runs but no water coming out of faucets.
welder is offline   Reply With Quote
Old 07-18-2018, 11:08 AM   #2
MillMitch's Avatar
Are you sure there's water in the fresh water tank? I'm asking because we just camped this weekend. I filled the freshwater tank at the campground, then headed to site. Water was coming out of siphon all teh way back to our site and stopped draining shortly after I got setup. Not sure how much siphoned out, but we made it 3 days with what was left.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 07-18-2018, 11:09 AM   #3
Kanadian Kamper
kenandterry's Avatar
Uhhhhhh....for sure there’s lots of water in the onboard tank?
If not.....you run the risk of burning out the pump motor.
Has it worked before? How long ago?
Ken and Terry
kenandterry is offline   Reply With Quote
Old 07-18-2018, 11:16 AM   #4
jeff64's Avatar
1st trip of year and selector at pump inlet still in the winterize a/f fill position? Check valve in city water inlet connector leaking/ pulling air? Is there at least a cap/plug on city water connection which should rule out check valve?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 07-18-2018, 11:57 AM   #5
I checked all the above still NG
Old 07-18-2018, 12:40 PM   #6
njfishing's Avatar
A few things I would check to get to the root cause....
First thing I would do is take the water supply line to the pump off (the one ruining from your tank to the pump) and see if I could suck some water out of it... If so you can eliminate that part of the system...
If that checks out next step is pull the water line coming out of the pump off start the pump and see if it's pumping water. If not and the pump runs then check out the pump itself. If it's like most you have pump diaphragms (they are little rubber plungers) that could have something fouling them or they could be shot. In either case either clear them out or note the pump model and order replacements daiphrams.
Here's a video for you which shows you some other troubleshooting routines.
If it does pump water, then your issue is downline somewhere.
Could be your by pass vales turned the wrong way when you winterised it or perhaps your low point drains are open and the water is pumping out of them.
Hope this helps.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is offline   Reply With Quote
Old 07-18-2018, 04:28 PM   #7
Hope this helps.
Old 07-18-2018, 05:35 PM   #8
Originally Posted by welder View Post
I did all of that it looks like the pump is bad.[emoji853]
Old 07-19-2018, 09:44 AM   #9
njfishing's Avatar
Well if the pump runs but won’t pump water its the diaphragms so clean them out or replace them its an easy job.
Gerry Z
Curt Trutrack WDH
Old 07-19-2018, 09:54 AM   #10
Jim34RL's Avatar
I also have an inline inlet screen before the pump in my trailer. I would make sure that the screen is cleaned and free of debris. This will un-screw and than you can clean the screen. This is one of the first items I clean when de-winterizing the trailer for the season.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 07-19-2018, 10:07 AM   #11
Just as a check, disconnect the output line and run the pump. Maybe it just lost its prime.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
rskeans is offline   Reply With Quote
Old 07-19-2018, 10:58 AM   #12
Tried ng
Old 07-20-2018, 01:35 PM   #13
Tried ng
I changed the pump. I’m good to go.
Old 07-20-2018, 01:44 PM   #14
DavidMPDK's Avatar
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
pump, water, water pump
