Old 12-30-2017, 09:17 AM   #1
Water Pump not running----HELP
FR3 30DS 2018 Dry Camping in NC and got a sudden cold snap. Woke up with no water. Water pump will not run. Had Heat Pads on all nite but did not put rv anti in system (my bad) Any ideas. Is there a switch on the Sureflo Pump that I need to reset or what..I at a loss....Tried warming up pump lines with hairdryer t no avail....
George (Retired US Air Force)
Beverly (Retired Travel Agent)
2018 FR3 30DS
fritzg2 is offline   Reply With Quote
Old 12-30-2017, 09:52 AM   #2
cavie's Avatar
Trailer waterline may be frozen. The pump can't move water and shuts off. Disconnect the water line from the pump to the trailer and see if it runs. Then move on down the line. Try draining the lines and see what happens.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 12-30-2017, 10:22 AM   #3
Flybob's Avatar
If the pump froze, it could blow the fuse while trying to run a stalled motor.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-30-2017, 10:32 AM   #4
BINGO....removed the access panel and yes it had blown the 10 amp fuse...replaced it and it ran. Pulled some pink RV Safe Anti thru it and all seems ok now....THANKS
2018 FR3 30DS
Old 12-30-2017, 10:52 AM   #5
cavie's Avatar
I love it when a plan comes together.
Old 12-30-2017, 11:22 AM   #6
Mr. Dan's Avatar
Good job, Bob.
... and OP, thanks for posting your resolution!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 12-30-2017, 02:42 PM   #7
Tom48's Avatar
Originally Posted by Mr. Dan View Post
Good job, Bob.
X2
Tom48 is offline   Reply With Quote
Old 12-31-2017, 04:10 PM   #8
Where was the fuse located? In the main distribution panel or just an odd one close to the pump? Ive got a similar problem in SC but worked around it with a heated water line.
bruane is offline   Reply With Quote
Old 12-31-2017, 05:18 PM   #9
Fuse located in the pump area in a capped fuse link which I noticed ony cos the top was open exposing the fuse (10AMP). Had to remove the panel to access it. Black panel held by four long screws
2018 FR3 30DS
Old 12-31-2017, 06:42 PM   #10
BillyBass's Avatar
glad you got it fixed.That's something to remember .Happy new year to you guys
2019 Flagstaff 26 RBWS
2005 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
pump, water, water pump
