03-23-2014, 02:29 PM
Water when dry camping
Can't get water to run inside unit off of my fresh water tank. The pump is running but no water? HELP!!
03-23-2014, 02:41 PM
First make sure there is enough water in fresh water tank. Second check if you have a winterizing valve on the intake of the water pump and if in proper position.
Fonzie
03-23-2014, 02:42 PM
Tank is 3/4 full. Where is the valve??
03-23-2014, 02:43 PM
If you have one by the water pump.
Fonzie
03-23-2014, 02:44 PM
Questions: Was it winterized before this if yes check your bybass winterizing valves.
Have you used it this year yet?
Is it still cold where you are?
What kind of camper do you have?
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
03-23-2014, 02:48 PM
I found 4 valves. Played with all of them but still water. Can't wait to give my dealer an ear full. This is pure BS!!!
03-23-2014, 02:58 PM
Maden voyage. Worked good off of campground water. Nothing off of tank.
03-28-2014, 01:28 PM
HAPPY WHEN RV'ING
Is this problem on a FR3? I've not had this problem on mine. Are you sure the water pump is pumping properly? Just because it's making noise does not mean it's pumping. Try disconnecting the water line between the pump and sink to see if any water comes through.
Keep in mind, what may be on 1 mfg. may not apply to another. Best thing to do is contact your dealer and see if they can offer any advice. I've found that if they can help you over the phone, they will.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
03-28-2014, 07:53 PM
First time with my FR 3 I had the same problem but it turned out I had not turned on the valve near the pump. Then I learned the importance of putting the anode rod in before the pink stuff squirts out into your hair!
On my ole trailer the pump would sometimes airlock if i did not open all the faucets and let the pump run and run.
03-29-2014, 02:48 AM
We had a strange thing with our water once... Dry camping, no hook-ups, all the water ran fine with the pump except for the toilet!! We had to keep a cup on the bathroom counter to flush! All of a sudden it started working on day 3 of our 4 day trip... Told dealer about when I for other repairs. Not sure if they really looked into it, but strange it flushed just fine with full hook ups, but not on water pump...
04-05-2014, 07:33 PM
Same thing happen to me this weekend camping in the desert. What was your outcome, how was it corrected...Thanks
04-05-2014, 08:20 PM
Here is a plumbing diagram to help you get an understanding on how the system functions. Let us know what happened.
Water, Water, Everywhere!
04-06-2014, 07:21 PM
this is the valve and it needs to be pointed like this to get water from the fresh water tank.
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
04-06-2014, 08:46 PM
Right, ya that the way I have it, but no toilet water. Tried all kinds of options...
04-06-2014, 08:49 PM
DW's 401(k) Plan
Wow, that's quite a kink in the hose next to the door!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
04-06-2014, 08:52 PM
That hose seems to be an auxiliary hose with a termination plug. Does not go any where, at leat in my rig..
04-06-2014, 09:36 PM
I opened and closed that valve 20 times and still never got water out of my tank. Unit is at the dealer now. Hopefully they will solve the mystery.
04-06-2014, 09:42 PM
Please share results...thanks
04-06-2014, 09:57 PM
that's just the hose for winterizing, you straighten it out when you put it in the jug of anti-freeze
2014 FR3 30DS
04-08-2014, 11:10 AM
Ok for those who are interested my water problem turned out to be a bad water pump
