Old 01-25-2018, 09:08 AM   #21
I'd bet poor connection.
2011 Traverse LT, 3.6L, FWD
Old 01-25-2018, 05:46 PM   #22
Mmmm have to check all connections to see if one is loose or not connected...thank you
lazbo is offline   Reply With Quote
Old 01-25-2018, 08:40 PM   #23
TLAK's Avatar
Why wonít the back tv work as the two front TVs...is there a switch I am missing or do I have to run a coaxial cable with a splitter?
On my 2015 the rear TV is not wired to the DVD. Antenna and cable only. That's how it is built.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 01-26-2018, 11:22 AM   #24
Iím sure people who donít own an fr3 ,,, are answering these questions. Iím sure the man knows itís a coaxial cable . The problem is this rig is not near a tv and in a weird place... so you just donít drape a cable across the room across the sink blah blah. .. if you remove the two screws you will see there is also a co axis outlet on the back... we drilled a hole through the cabinet. To the back of the tv in the kitchen and rigged up our router... it is no doubt in the wrong place and begs one to ask. What and why....
colourful64 is offline   Reply With Quote
