Old 06-28-2015, 12:06 PM   #1
what items can be used while AC is running at campsite .
Can someone please help me out on this. What items can be used while at a campsite when the AC is running. Example: Can you use microwave, hairdryer and other electrical appliances? I don't mean all at the same time, just one or two.
progolfer is offline   Reply With Quote
Old 06-28-2015, 12:11 PM   #2
fonzie's Avatar
What size supply do you have? 30 or 50 amps
Just add the amps draw and do not go over your max allowable main breaker rating.
normal appliance amp draws
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-28-2015, 12:13 PM   #3
Ford Idaho's Avatar
Smile
30 amp?
With A/C
No hair dryer, no micro.
Coffee pot perhaps.
Electric frying pan maybe
Kind of sure you can use chop sticks but I forget how many amps they pull...
Old 06-28-2015, 12:14 PM   #4
Witch Doctor's Avatar
It going to depend on if you have 50 amp or 30 amp? I'll attach a chart to show you what each things pull in amps.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-28-2015, 03:12 PM   #5
bigduke1956's Avatar
A/C
we used the AC and Microwave both at same time, was not an issue for our 30A unit
BTW Chopsticks run well on caffeine
Mike & Sun
Pets - Piotti, Kongatti
2016 Georgetown 369 XL
US Army 22 years
Days Camped
2015 - 50+ days
bigduke1956 is offline   Reply With Quote
Old 06-28-2015, 03:35 PM   #6
It's doable some times. Running, the A/C's probably pulling 1500-2000w, tack on 1000w for a standard MW. 3000w +/- with 600watts to spare an 30A. You just don't want your converter to be charging or have the WH kick on. Timing is everything.
rana is offline   Reply With Quote
Old 06-28-2015, 10:56 PM   #7
Same here....as long as water heater is on propane and no one cranks up the electric skillet or hair dryer!!!
We find we can run any 2 large power items (ac, microwave, elec skillet, hair dryer, elec water heater) along with several smaller use items. (Lights, fans TV). As soon as you add that third high use item, she pops a breaker.
jrwalkerpa1 is offline   Reply With Quote
Old 06-29-2015, 02:30 PM   #8
Don't Blow your Breaker
30 amp or 50 amp? Note attached AMP Chart. This will give you an idea as to what you can run.
tomrob1161 is offline   Reply With Quote
Old 07-01-2015, 09:02 AM   #9
Never had an issue with the AC blowing anything out. However, The toaster oven and electric griddle running together get it every time, but only blows out the kitchen, if I move the griddle I'm good. lesson learned.
David 01 is offline   Reply With Quote
Old 07-01-2015, 09:22 AM   #10
jeff64's Avatar
Buy a plug in voltmeter, stick it in an outlet you would have to look at all the time. Pay attention to what it tells you
