Old 01-07-2016, 08:59 PM   #11
leisurelarry's Avatar
They are H rated.
leisurelarry is offline   Reply With Quote
Old 01-11-2016, 12:23 PM   #12
Harleyreb's Avatar
14K miles on my Goodyear G670's, and the front tires also needs to be replaced. Has anyone ever looked at or used Hankook tires?
2015 FR3 30DS
2014 Jeep Cherokee Latitude
2017 Jeep Wrangler
Harleyreb is offline   Reply With Quote
Old 01-11-2016, 07:27 PM   #13
What tire to choose?
I just got 2 Michelin's, the same as Leisure Larry. I also had them check the alignment. The toe-in was way off. Hopefully now I can keep these for a long time.
Also, what pressure do you keep in your tires? The tire store recommended 92, and the sticker on the coach says 82. thoughts?
dutiful Don is offline   Reply With Quote
Old 01-11-2016, 07:48 PM   #14
Got 2 Bridgestone 245/70-19.5 R250 on my fronts. So far very happy with them. Price was horrible but what can you do at night, in a truck stop, on a wreckers tow hook??!!!
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 16 days
mogman is offline   Reply With Quote
Old 01-11-2016, 09:23 PM   #15
@dutiful don, That 82psi is only applicable for the OEM tires, the Goodyear G670. So ignore that now on since your using some Michelins.
Get your rig weighed out at a truck stop. Most say to get a 4 corner weigh, but I've only used the axle scales at the truck stops. You'll find out that the 30DS is close to your axle rating in the rear if not over. And your steers have room to spare. Once you get the weight ticket from the scales, take a look at the loading chart here.
I'm guessing for the XZE, the lowest PSI listed is 75psi, which is the lowest you can go regardless of your weights. With the Goodyears, it was 80 psi. Enjoy your new kicks.
Michelin RV Tires | View Michelin RV Tires load and inflation tables for motorhomes and recreational vehicles. | Michelin RV Tires
KansasFR3 is offline   Reply With Quote
Old 01-11-2016, 09:23 PM   #16
The posted maximum PSI on my Michelins is 120. The installer recommended 100 PSI cold with my front GAWR. The coach drives and steers wonderfully.
tire
