Old 12-01-2018, 11:03 PM   #1
What to look for during purchase?
Hello all! New to the forum, been lurking awhile. We're picking up our FR3 32DS this week and are very excited to start hitting the road with the family and seeing the US/Canada! We've only taken 1 RV trip, in a Thor Four Winds 30D, but are eager to get started and learn as much as we can.
My first question -- is there anything specific I should keep an eye out for, check, evaluate, etc. as a part of the walkthrough/pickup process? We're buying one of the last 2018's on the lot so it's probably spent the year on the lot. Has some miles on it from a few shows they took it to, but otherwise seems ready to roll.
What would you look for and inspect before signing papers? Thanks!
Griswards is offline   Reply With Quote
Old 12-01-2018, 11:08 PM   #2
every thing. plus about a 3 hour walk through and explanation of all systems so you understand how things function. or you will be wondering why your ac doesn't work off the batteries if you have never owned an rv before.
Kimber45 is offline   Reply With Quote
Old 12-01-2018, 11:21 PM   #3
X2
Either videotape or take notes during your walkthrough and don't sign the papers until everything works. We would not sign the papers til everything worked and you should have seen the techs come out of the woodwork to get everything repaired in two hours. Then we signed the papers.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 12-02-2018, 08:21 AM   #4
Make sure to ask about any recalls and if they have been taken of. we purchased the last 17 32DS Feb this year and we even asked about recalls and dealer told there wasn't any, wrong! there was a recall for roof leaks. recall notice was issued September of 2017. just got it back yesterday after almost 4 months at factory to replace roof. there were other issues where coach was in shop numerous times. I am hoping everything is ok now. just be very, very thorough when going over coach before you sign and give them lots of money. wish we had.
wnewman53 is offline   Reply With Quote
Old 12-02-2018, 01:46 PM   #5
Grapehound's Avatar
Before I buy (because I am cheap), I would suggest you search all over the internet for that year and model and see if the price can be brought down due to better offers elsewhere. Buying the first trailer you like at the local dealer may not be the best deal for you. Even if you have to drive a ways, you can stay in the trailer on the way home.
I have often seen local dealers asking $2-3k more than the same unit can be bought elsewhere, not to mention you may find one with more options (fireplace or second AC) for the same or better price. Be ruthless in your search for the best value, then hold the dealer's feet to the fire about their warranty and what they cover. Get it in writing.
Make sure all systems work before you drive it off the lot.
Have them adjust your hitch for you so the trailer is at proper height before you drive off the lot. Your maximum clout is before you sign the papers. After you sign it can sometimes be a case of "What did you say your name was again?"
If a dealer is unwilling to work with you before the sale, multiply that by ten for after the sale.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
Grapehound is offline   Reply With Quote
Old 12-02-2018, 02:02 PM   #6
During your walk through, your dealer will want to show you how things work.
Tell him/her "No." You tell me how to operate it and I'll do it myself.
Exercise EVERYTHING. This means everything, including the speaker-balance switch on the radio and the dimmer switch on the driver-console. Everything! (This is why people say it will take 3 hours to do the walk through.)
Have them bring out an electrical receptical tester. Test every electrical outlet so you know which ones work on the inverter and which are strictly on shore power or generator.
Ask them to check the air pressure in all tires and watch them do it. I got mine home and one of the dully tires was 'clocked' wrong and I couldn't get to the valve stem. Had to pull the wheel and rotate it.
Checking the air pressure will also assure the beauty rings (chrome wheel covers) don't obstruct the valve stems.
If they have difficulty checking the air, have them add valve stem extensions. You don't really want to pull the chrome covers just to check the air pressure.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 12-02-2018, 02:23 PM   #7
[QUOTE=McCormickJim;1983379
If they have difficulty checking the air, have them add valve stem extensions. You don't really want to pull the chrome covers just to check the air pressure.[/QUOTE]
THIS!
While it may not seem like a big deal, it really is!
And what everyone else said, X 100.
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 12-02-2018, 03:31 PM   #8
new rv's OOOOOOOH!
be picky ,catch the defects now! I have seen (as most rv folks do) all kinds of braindead items fresh from the dealers. if you have a hot water tank make sure the anode rod is A. installed - B. new and C. the water flows through it . Also check the date on the Tires ,be sure they are the same year or only 1 yr old as the rig they are installed on . most wheels are not covered by the dealer unless they installed them as an option from a 3rd party (lionshead,etc) even then you will be dealing with them not the dealer. If it has sat on the lot for a year find out why! Many RV owners find out to late that the rig they just bought and loved was a factory or dealer fixer upper ! damaged during delivery/transport or defective from the start and returned or traded for a different one .Remember buyer beware the dealer is under no obligation to inform you of any recall/defect known or unkown to them -you are also under no obligation to patronize them either ,so be ready to walk away from a bad deal regardless of what the dealer says he/she will do "after" you sign on the line . if all fails and you already did and you are not getting help from the dealer or mfg. your state attorney general maybe of help.
luckieman is offline   Reply With Quote
Old 12-02-2018, 05:02 PM   #9
jkoenig24
Find and attend an RV Boot Camp BEFORE you buy. MANY (most?) of your questions will be answered at RVBC. The Escapees RVBC is EXCELLENT, usually run over a weekend. Other groups offer their own version of RVBC (FMCA, RVSEF, RV~Dreams etc). Some go as long as eight days (more social activities). Mistakes made with RVs are often expensive and, sometimes dangerous. RVBC will explain and demystify all the systems found on a modern RV. RVBC graduates are smarter RV buyers and safer RVers in general. Some insurance companies offer discounts to RVBC graduates. RVBC will be a wise investment in your RV lifestyle and, is WELL worth the time and money. Attendees can stay locally (motels or, camping cabins) and drive in to the event each day. Just DO it; you'll be happy you did!
Regards,
John
jkoenig24 is offline   Reply With Quote
Old 12-02-2018, 05:43 PM   #10
Flybob's Avatar
Don't let "very excited to start hitting the road" cause you to do something you will regret later. Make sure everything is the way you want it before you sign papers and leave the dealer. If this is in Indiana it is most likely winterized. Insist the dealer dewinterizes it and demos the water system then rewinterizes it. Many dealers will tell you to sign and take the unit then after you have used it for a while, you can bring it back for warranty work as you have a year. For many dealers, once you sign and leave they forget who you are. Your warranty repairs will go to the end of the line behind full price paying service. Before you sign you will be at the top of the list. If the dealer has the ability spend a night on the dealers lot actually using it before taking it home.
Enjoy it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
