Old 02-09-2017, 11:49 PM   #1
Why does my furnace come on and run forever and once shut off never come back on again
Furnace Problem on a 30 ds
lazbo is offline   Reply With Quote
Old 02-12-2017, 10:18 AM   #2
ceedog's Avatar
Have you checked your thermostat? The thermostat determines when/if you need heat & how much.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 02-12-2017, 10:28 AM   #3
I have been thinking it was the thermostat as I have to shut it off and turn it on after to get it working once again after it never seems to shut off...New motorhome and this just bugs me....thank you for responding
Old 02-17-2017, 10:06 AM   #4
ceedog's Avatar
laz,
Were you able to resolve the problem?
I've installed numerous thermostats for various applications & about 10% of them have been defective.
Old 02-17-2017, 10:14 AM   #5
Originally Posted by ceedog View Post
laz,
I think we will wait till we get home and then I will take it in to get fixed as it's new and under warranty.
Old 02-17-2017, 10:20 AM   #6
rotorhead1250's Avatar
Lazbo, I had a TT that did this exact thing. Swapped out to new digital thermostats and that fixed the problem.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 02-17-2017, 10:35 AM   #7
X2.
2011 Traverse LT, 3.6L, FWD
Old 02-17-2017, 06:19 PM   #8
Originally Posted by rockfordroo View Post
X2.
Thank you for responding.I will check it out once we get home only need it in the morning as we are in Yuma now.It worked when we first got it but then only once and had to shut it off and turn it on after awhile later
Old 03-27-2017, 03:02 AM   #9
Ours is the same when it is on the battery. So it's a battery issue they say
colourful64 is offline   Reply With Quote
Old 03-28-2017, 05:52 PM   #10
Antone's Avatar
I had mine on fan instead of auto (au) and it just kept blowing until I figured it out.
Antone is offline   Reply With Quote
furnace
