Originally Posted by auntieshoes
Brewster - Not yet, but the dealer has 2 other things they wanted to try this week so I have decided to lay low and wait to hear from them. Are they working on figuring out your AC problem or other issues?
Coot and Kickin - Here is some language from the FR customer service FAQ page:
FREQUENTLY ASKED QUESTIONS
Q-How can I obtain schematics of my Forest River RV product?
Forest River RV does not publish schematics of our products. Should a technical concern arise, we would recommend contacting your local Forest River RV dealer.
Be careful if you expect the wiring diagram to help. I bought a full set for the coach portion of my Coachmen rig. There are no wire color codes so tracing a wire means you basically need to trace the wire by hand which may mean pulling it from the harness.
Some wires change color when/if there is a connector in the line. You may also discover numerous wires in your RV that are not shown on the drawing. I was told by FR that this was because they used the same harness for many different coaches. Not sure how having extra wires lowers costs and it certainly doesn't make solving electrical issues any easier but then again after a year they can wash their hands of your problems and you can pay to have a tech to try and figure out where the wires go.
I had my Battery Disconnect solenoid go bad and after a few hours I confirmed the wiring diagram was drawn with the solenoid in backwards on the drawing showing a light bulb with both connections going to ground!.
If you get a diagram consider it a drawing of suggestions.
.Write a blog on RV tire application
RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
