Old 11-18-2015, 02:06 PM   #1
Window metal handles fall off?
FR3 30DS 2013 model
The bar used to push open the window keeps slipping off.
Tried putting the rubber and bar back on. Still keeps coming off after one or two uses, opening and closing the window.
Trying to figure a way to keep it on.
Suggestions??
Ron C
2013 FR3 30DS
From Iowa on US tour!
Ron Chamber is offline   Reply With Quote
Old 11-29-2015, 10:14 AM   #2
Same issues, I'm thinking silicone caulk
rzrnaz is offline   Reply With Quote
Old 11-29-2015, 12:56 PM   #3
dan-nickie's Avatar
I used silicone to fix mine on a Class C a few years ago. Worked fine until I traded it in.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-20-2016, 06:25 PM   #4
I have same problem I think. Click image for larger version
Name:	ImageUploadedByForest River Forums1466464953.572675.jpg
We open and close this dinette window a lot, so I would like to fix it right the first time. Could one of you give me details on what you did and how long it held? In the meantime, is there any danger the window will fall out while driving?
Z
2014 FR3 30DS
Z Maze is offline   Reply With Quote
Old 06-20-2016, 07:37 PM   #5
fpo1123's Avatar
I just had the same problem. I used goop adhesive. I put some inside the rubber and put that back, then added some to the metal handle and pushed it back over the rubber. Dried overnight and it is holding tight.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 06-21-2016, 08:40 PM   #6
Thanks I will try that!
