Old 11-15-2017, 12:25 PM   #1
Winterizing
What pressure should I set my compressor to when blowing out the lines?
welder is offline   Reply With Quote
Old 11-15-2017, 12:52 PM   #2
41 PSI! Youroo!!
Old 11-15-2017, 12:52 PM   #3
Ejs4029's Avatar
I did mine at 40psi.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 11-15-2017, 12:54 PM   #4
You'll probably get a wide range of responses for this. Most people say somewhere between 20 and 50 PSI.
Split the difference and go with 35.5
Iwritecode is online now   Reply With Quote
Old 11-15-2017, 01:14 PM   #5
NMWildcat's Avatar
The Answer to the Ultimate Question of Life, The Universe, and Everything, including psi for water line blowout is 42.
Scott and Liz - Southern NM
Old 11-15-2017, 01:17 PM   #6
Heh, I did 60.
Turn it up to 11!
aeblank is online now   Reply With Quote
Old 11-15-2017, 01:20 PM   #7
0-psi. I don't use air and just let the Antifreeze push the water out.
TheWolfPaq82 is offline   Reply With Quote
Old 11-15-2017, 01:24 PM   #8
Dang... I had really believed it to be 41.6 PSI.
No wonder there are no pots of gold at the end of my rainbows!
Seriously, most all commercial R/V water pressure regulators are in the range of 40 to 55 psi. Air is no different. Set your regulator accordingly.
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 11-16-2017, 09:35 PM   #9
Goofy1's Avatar
You guys enjoy freaking out this noob don't you? I read and read and finally settled on 35psi and then I read this and it's like OMG, do I need to go do it again?? Fingernails to the nubs!!!
Hopefully I can learn plumbing repairs if the need arises!!
2017 FR3 30DS
Retired MSG from US Army
Goofy1 is offline   Reply With Quote
Old 11-17-2017, 10:31 AM   #10
NMWildcat's Avatar
Don't see anything in the above posts that should freak anybody out. They are all viable, useful answers. It's not like it's rocket science.........
winter
« GPS | oil change »
